Projects Firing order model b banger solved, first test drive RPU
Discussion in 'Traditional Hot Rods' started by Zottel, Jan 12, 2023.
  1. Zottel
    Zottel
    Am I right or wrong?
    It fires a little bit but wont run.
    Its an FSI
    The say 1 is at right down then2 at right up....
  2. coupeHEAD
    coupeHEAD
    sko_ford likes this.
  3. Zottel
    Zottel
    1 is at the front? Not at the clutch?
  4. coupeHEAD
    coupeHEAD
    Yes
  5. Zottel
    Zottel
    I think my baterry was just to low for the fsi
    It fires now after charging
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Full charge is key with FSI. You can also bump start it if need be.
    Tim and Zottel like this.
  7. Zottel
    Zottel
    I started it with charger on , it worked
    ...every day is a school day as winfield says...
    So now I made the first test drive on my property in cold rainy german weather...
    That was fun!!!
    Toms Dogs, brading, vtx1800 and 12 others like this.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Go man go!
    winduptoy and rusty valley like this.
  9. Zottel
    Zottel
    I worked 12 hours a day for the last 6 days to get things going...i want to have this thing on the road by february
  10. brady1929
    brady1929
    Where do you live in Germany?
    Outback likes this.
  11. Zottel
    Zottel
    Ruhr valley
    Also have a property in east germany (ex GDR)
    51 mercules likes this.
  12. Zottel
    Zottel
    So I built a bar for the headlights...
    Toms Dogs, v8flat44, Chucky and 5 others like this.
  13. Zottel
    Zottel
    Pushin it foward
  14. Zottel
    Zottel
    Yesterday I made the first test drive on the street but I have some serious issues with backfire it does not run smooth at all.
    I spend 4 hours on Timing and carburetor... and allways went back to where I startet... I marked the distributor and counted the revolution of the screw.
    I have an fsi and a Weber. Has anyone some advice for this setup.
    I think its running to rich.. but does this makes the backfires ?
  15. winduptoy
    winduptoy
    backfiring out the carb or the tailpipe? pull the sparkplugs and have a look see at them to get a rich/lean condition
    and I'm going to ask if you've done a compression test?
    I'm not real schooled on the Weber but have a buddy that is running one on his banger and as I recall there was a challenge getting the intake to be leak free so that would be another place to look at.
  16. Zottel
    Zottel
    The engine is rebuilt I haven't done a compression test because of that so far.
    The plugs are black so really too rich.
    Ive orderd smaller main jets, maybe that will help.
    The backfires are in the tailpipe not the carburetor .
    It revs up ok. But if you hold it a fixed RPM it runs rough and backfires.
    The manifold gasket is brand new... I tightend it up again when it was warm.
    It has some serious power I went easylie down the road at 50 but runs rough trugh the whole RPM allways a little backfires
  17. jaracer
    jaracer
    Backfiring out the tail pipe sounds like either an ignition or a compression problem.
  18. winduptoy
    winduptoy
    Based on the plugs and the backfiring out the tailpipe I would agree that it is rich.
    According to my buddy, the Weber has 35 primary jets and 40 secondaries. Don't know if you've verified the existing jet sizes
    I suspect that you are on the right track with some jetting changes
    As for the timing, I know that Nu Rex makes a timing accessory that is mounted on and affixed with the front motor mount. That might be an aid in ultimately setting the timing.
    Carry on
  19. Zottel
    Zottel
    Long story short... I need bigger main Jets although the plugs were black ...because the secondary throttle was not opening correctly....so it ran rich but now as it gets enough air, its too lean.
    If I pull the choke 1/3 it revs up perfect.
    ..so I orderd another jets:rolleyes:
    Took me nearly 2 days to figure out....
    winduptoy likes this.
  20. v8flat44
    v8flat44
    Enjoy that cool Banger ! "B" safe & have fun; I'll B watching ..... :)
    Outback, Zottel and Budget36 like this.
  21. Zottel
    Zottel
    Beside that I did some wirering and made some twisted steel brackets for the taillights.
  22. Zottel
    Zottel
    Now i bored out the jets to 150 and finally it runs good, so I did a short ride in the snow...
  23. Zottel
    Zottel
    Put the first miles on the banger after weeks of rainy weather ... it has serious power and will go easy 65 Lots of Fun!
    Jeff34, Toms Dogs, Petejoe and 3 others like this.
  24. dmar836
    dmar836
  25. winduptoy
    winduptoy
    Good on you...you kept with it....
    Bangers are fun where 65 feels like 165
    Zottel likes this.
  26. Petejoe
    Petejoe
    from Zoar, Ohio
    Cool. I’ve always wanted a banger. Sounds like you have a good one and a great setup.
    winduptoy and Zottel like this.
  27. Zottel
    Zottel
    They make a nice couple:)
    The more I drive the banger, the more i like it, but here in germany its rainy for the last 3 months nearly every day, so it didn' drove so much. Also was working on some other projects!
    Outback, winduptoy and Petejoe like this.
  28. Outback
    Outback
    from NE Vic, Oz
    So what has been done with the engine? Cam etc?
  29. Zottel
    Zottel
    Fully rebuild, Mild cam , more compression, FSI and Weber carb.
  30. Ebbsspeed
    Ebbsspeed
    @Zottel That looks like a real fun RPU! I like this photo of the building with the cars in it. Tell us about it, and maybe some photos of the building. Screenshot_20230122-231348_Gallery.jpg
    Outback and 51 mercules like this.
