Projects First build: 31 truck
Discussion in 'Traditional Hot Rods' started by OWes21, Dec 30, 2023.
  1. OWes21
    OWes21
    My first real project and build. I'm really excited to get started.
    Learning a lot from all the posts and comments on the forum so thank you!
    Okie Pete, Budget36, swade41 and 5 others like this.
  2. 31Apickup
    31Apickup
    Good luck on your first build. Your cab looks to be started from a cut down Tudor sedan in car you didn’t know.
    ClarkH and OWes21 like this.
  3. bill gruendeman
    bill gruendeman
    Good luck on your first project. Try to get something done every week and don’t give when it takes longer than expected, plug away a bit at a time
  4. OWes21
    OWes21
    You want to tell me why?
  5. alchemy
    alchemy
    The 30-31 pickup cabs didn’t have the vertical seams up the back side, like sedans did. That, and we can just tell by looking cause the shape is a bit different at the corners.
    As an aside, I’m pretty sure the doors are the same for pickups and tudors in 31, so those are “real”.
    31Apickup likes this.
  6. hotrodjack33
    hotrodjack33
    I agree with @alchemy The rear is from a sedan.
    But, that's OK. It will still make a cool hot rod!!!
    '31 Pickup
    '31 Sedan
  7. :cool: I really like the look of the back of @OWes21 's truck cab !
    manyolcars and OWes21 like this.
  8. 2Blue2
    2Blue2
    Right On!
    Thats gonna be neat!
    I Digs it!
    OWes21 likes this.
  9. Toms Dogs
    Toms Dogs
    from NJ
  10. hotrodjack33
    hotrodjack33
    ...and with the sedan panels, it looks like you may have gotten an extra 3 or 4 inches length inside the cab...which is a real bonus.:)
  11. OWes21
    OWes21
    Thank you for the input! I thought it looked a bit off compared to all the pickups I've seen online. At first I was bummed but I think it'll add to the history of the truck.
    The truck has been in the corner of a shop for 30ish years. Trying to find out some more information.
    Would the serial/VIN be specific to a sedan or truck?
  12. alchemy
    alchemy
    No. Just the number that the engine came down the line.
    OWes21 likes this.
  13. ClarkH
    ClarkH
    Nice project! I'll be following; since it has a Washington ***le I ***ume you are from the Lake Stevens that is just up the road from me.
    As alchemy notes, serial numbers are not model-specific. They are sequential, however, so you can figure out the month/year the frame and engine were ***embled. Presuming everything is original, which isn't the case more often than not. No serial numbers on the body, btw, unless Washington State added one.
    And as said by hotrodjack, the fact that the cab is made from a sedan is a good thing in the eyes of many. Space is at a premium in Model A trucks, and the sedan back can make for a slightly bigger cabin. (I have a '29, which is even worse!)
    No reason to be bummed, it's a hot rod! I wouldn't blink an eye.
    OWes21 likes this.
  14. ClarkH
    ClarkH
    Also, I see you have a stainless radiator shell. That is also p***enger-car specific. I'm pretty sure a PU would have come with a painted steel commercial shell. This was PU specific in '31, and not to be confused with the big AA commercial shell. Thing is, stainless doesn't rot and a lot of guys prefer the shiny look, so the shells got swapped out a lot.
    31Apickup and OWes21 like this.
  15. OWes21
    OWes21
    Again thank you everyone for your input. It's amazing how much people know about these rigs.
    Plan to get it all cleaned out and the cab off the frame. Then make sure the frame is straight.
    Want to go as traditional as possible but also don't want to spend a fortune and take forever lol
    Okie Pete likes this.
  16. OWes21
    OWes21
    Picked up a 1967 327. I haven't done much to it besides pulling valve covers and intake off to see what's under them.
    I will drain the oil and see what all needs to be done in the next week.
    Okie Pete, swade41 and ClarkH like this.
  17. OWes21
    OWes21
    I also put the ch***is up for sale. It's a little rough for my ability at this point. So I have been debating on which frame manufacturer to go with. Boling brothers is what I am leaning towards. IMG20240120171335.jpg
  18. OWes21
    OWes21
    Ripped all many layers of fibergl*** and wood out of the roof. You can see where they spliced the Tudor rear section in.
    Okie Pete, Vic Walter and swade41 like this.
  19. OWes21
    OWes21
    Got the doors off finally. Between work and the royal pain it was I didn't think I would ever get them off.
    The roof was about 4 layers of plywood, Bondo and fibergl*** sandwiched together.
    Currently working on getting the gas tank out. It was going good until I got to the forward flathead screws. If anyone has any advice I'm I've love to know. The first two stripped right away.
    The frame went to an awesome person in Centralia. Renea Julson, they have been building cars for nearly 60 years. Once I get the funds I will order a new frame from Riley Automotive.
    Okie Pete and 2Blue2 like this.
  20. If the serial number matches the frame you might consider keeping it and boxing it. If you sell the frame and the number matches the ***le you might have a problem when the buyer tries to register their car with your serial number. Worry about the paperwork now and it will save you headaches later. I also have a '31 pickup but mine is the cheap one without a solid top and rollup windows.
    Charlie Stephens
    OWes21 likes this.
  21. gary macdonald
    gary macdonald
    Heres a picture of mine . 88493277-B058-4C45-AC09-FBB44444FEF0.jpeg 609C5A10-F568-46A7-AAAF-BD11BDA0AAAB.jpeg
  22. manyolcars
    manyolcars
    this is great! you get a few inches extra room inside and you want that. I have collected the back panel to do this. you will need to move the bed back or shorten it or stretch the frame
    OWes21 likes this.
  23. OWes21
    OWes21
    Awesome! The plan is to shorten the bed for sure. I am planning on shaping the front of the bed to line up with the cab.
  24. OWes21
    OWes21
    I looked all over the frame and did not see anything that would identify it specifically. I'm pretty sure the buyer is going to chop it up to repair another one.
    I wanted to run the original but I would like to get the truck pretty low. I work a lot so I decided I'm going to get one built.
  25. OWes21
    OWes21
  26. OWes21
    OWes21
  27. Grumpy ole A
    Grumpy ole A
    This is going to be an awesome build.
    OWes21 likes this.
  28. post hole digger
    post hole digger
    from 97370
    the vin number is underneath the cowl post on the top of the frame, You have the body off so clean it up and see if it matches ***le.
    osage orange likes this.
  29. post hole digger
    post hole digger
    from 97370
  30. Clean it carefully, preferably with a br*** brush to just attack the rust and not the steel. Being too aggressive with the cleanup can diminish the stamped steel numbers. Cars and trucks begin and end with a star. If it is a car, it is followed by a capital A, then the number. If it is a truck, the star is followed by two capital As, then the number.
