First Build Thread '29 Ford special coupe
Discussion in 'Traditional Hot Rods' started by Binger, Apr 14, 2015.
  1. Binger
    Binger
    from wyoming
    It's been a while since I have updated. Didn't get much done. Painted the rear end after a rebuild and started putting it back together.
    ImageUploadedByH.A.M.B.1445641304.687184.jpg ImageUploadedByH.A.M.B.1445641334.118981.jpg
  2. Binger
    Binger
    from wyoming
    Got a few things done the last couple of weeks. Rust repair! Rebuilt the rotten sub rail and fixed the quarter panel and wheel well on one side. On to the next side.
    ImageUploadedByH.A.M.B.1448414718.876730.jpg ImageUploadedByH.A.M.B.1448414737.972772.jpg ImageUploadedByH.A.M.B.1448414765.992079.jpg ImageUploadedByH.A.M.B.1448414818.513029.jpg ImageUploadedByH.A.M.B.1448414844.665372.jpg
    birdog, Dannerr and wedjim like this.
  3. Binger
    Binger
    from wyoming
    Thanks for the link Charlie. I am going to have to have a special hub built and then adapted to a modern disk. I wish I would have gone with the AA bell for the T-5 and I wouldn't have had to get a disc made for my application. I am glad that I have those pictures of what will work so I have a good idea of approximate dimensions of what needs to be done. Whatever I end up having built will be the center sprung hub. I have a brand new A clutch in my stash of stock parts that was built in the '60s (judging by the box that it is in) that I could use to modify for this. I also have a couple of original discs that can be rebuilt also. With the popularity of the T-5s I am a bit surprised I could only find one kit that would work. That kit was from Auto Restorations and is Poor quality. Not to mention that place is out of business. There has been a couple of threads about the safety of their open drive t-5 conversion for the model A. I am glad I went with the adapter to keep the torque tube.
    Dannerr likes this.
  4. birdog
    birdog
    from Monroe, UT
    Great build I will be watching this!
  5. waxhead
    waxhead
    from West Oz
    Looking good, keep the updates coming Binger
  6. salf100
    salf100
    Anyone have a link to that thread regarding the banger and T5 combo? What kind of speeds would it comfortably cruise at?
    I love this build and the very first pic of the car sittin in that field. That look alone would make me take it home! Keep it up. Love where your going with it.
  7. Binger
    Binger
    from wyoming
    Here is the link for the Torque tube adapter.
    http://www.jalopyjournal.com/forum/threads/jeep-t5-trans-in-the-torquetube.256226/
    I hope to be able to get about 60MPH with the t-5. may have to change ring and pinion to get much more. Also will need more HP to push it too. Especially at 6000 feet elevation in Cheyoming. The car sat outside my garage for about 25 years. Needed space for other things. Wish it hadn't sat out for so long. I wouldn't have had to replace ALL the wood in it.
  8. volvobrynk
    volvobrynk
    from Denmark
    http://www.jalopyjournal.com/forum/...to-freeway-speeds.963536/page-4#post-10868513
    There is a nice guy on here working on a Volvo M40 conversion, I know it aint a T5, but it seems promising. i dont know how avlible they are near you?
    But a modern transmission will always help an old banger come to life
  9. Autolite
    Autolite
    Subscribed. I'm also tall and you're doing a build that really appeals to me (no chop, no channel, banger build to start, and who knows where it ends,...). Good luck!
    Binger likes this.
  10. nunattax
    nunattax
  11. Binger
    Binger
    from wyoming
    I used marine grade I bought at lowe's. Then 2 good coats of semi gloss rustoleum.
    Dannerr likes this.
  12. nunattax
    nunattax
    way to go
  13. Binger
    Binger
    from wyoming
    Wow I haven't posted in a month and a half. Holidays and so on. Still working on wheel wells and now Cowl panels. Hope to have some productive days in the shop. Here is a couple new pics. I made some sheet metal clamps like some I saw here on the HAMB. ImageUploadedByH.A.M.B.1453338728.318534.jpg ImageUploadedByH.A.M.B.1453338743.516639.jpg ImageUploadedByH.A.M.B.1453338759.470264.jpg ImageUploadedByH.A.M.B.1453338784.136738.jpg ImageUploadedByH.A.M.B.1453338809.305361.jpg ImageUploadedByH.A.M.B.1453338833.061178.jpg
  14. barrnone50
    barrnone50
    from texas
    Really like what you are building ! Very clean work. What backing plates are you using? F2 Or ? Thanks George
  15. Binger
    Binger
    from wyoming
    I am using the 12" speedway set up. I had to modify them a bit to work on the back like you would '40 backing plates for the A rear end and grind the spindles a bit for them on the front. I have been trying to use a lot of vintage parts but I have bought a few new pieces.
  16. waxhead
    waxhead
    from West Oz
    Glad to see that you are still working on this Binger. Keep the updates coming.
  17. Prewar
    Prewar
    from Orlando
    Binger, I'm really diggin' what you're doing with this car. I'm hoping to make some progress and updates on my coupe.
  18. Binger
    Binger
    from wyoming
    Encouragement and inspiration from the HAMB keep me going. I have been to the hot rod hill climb the past two years to watch and I am pushing hard to be able to participate this year. Trying to dedicate as much of my spare time as possible to the garage. Lucky for me Mrs Binger wants me to get the car done as bad as I do.
  19. Motmo
    Motmo
    I love the work you doing. I'm about to do the same thing for a set of '40 radius rods for mine. My stock ones keep hitting the frame because I stepped it. Did you just cut the front end off and weld them on the shortened rod? Or did you have to do any reinforcing? Thanks for the build thread!
  20. Binger
    Binger
    from wyoming
    I welded the ends on to the shortened rods. I didn't feel any reinforcing was necessary. The bones were in great shape and there was plenty to weld to. If I have problems I will address them when they come up. With only running a banger I don't think I will have any problems.
  21. Binger
    Binger
    from wyoming
    I found this license plate light at the swap meet this last weekend. Exactly what I was looking for. Didn't find much else but a nice trip with the wife for the day.
    waxhead likes this.
  22. 1929CDAN
    1929CDAN
    Very good build I really enjoy it. Thank you for taking the time for all of the pics and info.
    Binger likes this.
  23. Binger
    Binger
    from wyoming
    ImageUploadedByH.A.M.B.1455928926.106302.jpg ImageUploadedByH.A.M.B.1455928950.217493.jpg ImageUploadedByH.A.M.B.1455928984.570969.jpg
    I have solved my clutch issues. Had to sacrifice a center section splines out of a t-5 clutch and an input shaft from a stock model a transmission. Had a machinist friend of mine build it. Decided to build this nifty adapter instead of welding to a clutch hub. This way I can use any stock model A disc.
    Tim, 47flyer, Johnboy34 and 1 other person like this.
  24. Binger
    Binger
    from wyoming
    I had a couple of hours in the shop today and dis***embled the windshield frame. Every thing on this car was rusty. I got all the screws out and the frame apart Without breaking the gl***. I was surprised it came apart as easy at it did. I thought for sure I would end up with a pile of gl***.
    Dannerr likes this.
  25. gearhead695456
    gearhead695456
    Binger what did you use for a bellhousing, the stock 3 speed one and how's it differ. Going through the planning of this myself. Thanks
  26. Binger
    Binger
    from wyoming
    I am using the stock bell on this project. Hence all the funky stuff with the clutch adapter.
    An AA bell is shorter and doesn't require any adapter. I believe that the pilot on the input shaft on the T-5 needs to be shortened to use the AA bell. Looking back I would try and find the AA bell housing. I already built my cross member and shortened the torque tube so I am committed to using the adapter I had built. If it doesn't hold up I will look into getting a clutch Disc made.
  27. gearhead695456
    gearhead695456
    Ok even with the AA bellhousing youd still need something in between the trans and bellhousing to adapt the different bolt patterns (?) and mount your pedals to? Great build by the way.
  28. Binger
    Binger
    from wyoming
    Thanks about the build. Its coming along. Not too much longer then its going into paint.
    There is a 1/2" plate that is between the bell and the trans. I think there is a pattern on the t-5 to torque tube thread. I am using stock pedals. There is a pic of that set up above. brakes uses a rod attached to a bellcrank I built on the side of my battery box with a '66 El Camino master cylinder. Here is a link to the T-5 thread.
    Tim likes this.
  29. Binger
    Binger
    from wyoming
    I received my alliance tag the other day. Put the car all back together for final checks before I take it apart to begin paint. Getting closer.
    kevinwalshe and waxhead like this.
