Technical First door panels 50 pontiac
Discussion in 'The Hokey Ass Message Board' started by Malibu406, Apr 4, 2022.
  1. Malibu406
    Malibu406
    First attempt at doing door panels. It turned out ok. Bought black pleated and tan vynil. Measured out panels and cut the vynil to allow 1/2” for sewing and an inch or so for folding over the back. Wife sewed them up. Used MDF board and clear coated with enamel. Glued vynil on then a vapor barrier. Need to make chrome trim to go over seems even though they look pretty good. Shouldve put thicker foam behind tan to make up for the thicker pleating. Learning as I go. A992CB71-01B9-4121-A2F1-B1E55DC9444C.jpeg 76619B64-9300-4691-8FD6-4D9EFB8BD826.jpeg 03FE7235-14CF-492B-9511-6EE2DCAA6E98.jpeg FE68433F-351E-4ABD-8EDE-E797B8C43C1F.jpeg 53F81D22-9DB0-4958-8664-71F0FF9110C3.jpeg
    Update. Took the chrome strips off the original and covered the seams. Then upholstered the arm rest. That was the hardest part of it all. Got to figure out a better way to do it.
  2. Phil 41 Chevy
    Phil 41 Chevy
    looks good
    Malibu406 likes this.
  3. Nothing wrong with that.... Looks good
  4. chevyfordman
    chevyfordman
    Isn't it rewarding to do things that most people wouldn't attempt to do. I say good for you and the wife.
    Malibu406 and Budget36 like this.
  5. Greg Rogers
    Greg Rogers
    Very nice, great job!
  6. Where's the bench seat? It'd go good with your new good looking 50's style door pannels.
    Malibu406 and Squablow like this.
  7. Stu D Baker
    Stu D Baker
    from Illinois
    I'd say you did quite well.
  8. fyrffytr1
    fyrffytr1
    What is the front seat out of?
  9. Malibu406
    Malibu406
    Thanks all.
    The mice ate the front and rear seat. They wanted $3500 to upholster them. I couldnt justify that. The seat are from a 96 delta 88 I had with a bad motor. The fronts are 6-way electric. They were pretty easy to make brackets and mount. The rear was tough cause I had to integrate the two seats together and sew an extension skirt on the cover.
    fyrffytr1 likes this.
  10. Malibu406
    Malibu406
    I took the arm rests apart and cut the s***ches so I could use the coverings as template patterns. Cut it out and the wife sewed them up. Not easy to sew, good thing the s***ches are hidden .
    All in all it was time consuming but not that hard. However to do it with visible s***ches and perfect sewing would be pretty tough I think. So leave that to the pros.
    1DD1D48A-C801-4CA1-AEC4-B2E98F4B92F6.jpeg AD59F632-76B0-4B27-805C-2EBEE3E5F672.jpeg 503B640D-5584-4C9D-A95F-0F0AEB8FC342.jpeg 024BD998-9D50-4D2D-9892-3502766A8A01.jpeg 106AA72E-D7F0-4866-8A10-E644D8EE6189.jpeg 37081909-F95B-45C3-ABFB-15D21DAF9EE1.jpeg 5A35E10F-1885-4BDB-BD01-C87B066DDEFD.jpeg
    6inarow likes this.
