Projects First drive in 40+ years
Discussion in 'The Hokey Ass Message Board' started by 1930artdeco, Nov 24, 2025.
  1. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Had my 57 country sedan tuned up at a shop last week. Got delivered and deposited in the drive way-backwards. No problem-just driver around in a circle and into the garage! First time she has moved under her own power in 40+ years. Felt really good even with all of her glitches. Here is a video of her running. She is at a high idle due to some vacuum leaks that I have to sort out. Then I will drop her down and lean her out.
    https://youtube.com/shorts/4FBwGP0xPRA?si=iNoQHBehbpXnUze3
    warbird1, leon bee, swade41 and 7 others like this.
  2. Bandit Billy
    Bandit Billy
    *****in! 40 years? Very cool!
    Sharpone and dana barlow like this.
  3. Budget36
    Budget36
    They tuned it with the vacuum leaks? Seems odd.
  4. jaracer
    jaracer
    Looks to me like it has a high idle because the choke is almost closed.
  5. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Yeah, he set it up to run that way temp. I have to change out intake gaskets, sand the intake to head surfaces and install a 1/2” spacer and re***emble. That should take out the leaks and then I will drop the rpm’s and lean her out.
    warbird1 likes this.
