First engine build: 8ba Ford Flathead
Discussion in 'The Hokey Ass Message Board' started by Nevala, Dec 30, 2010.
  1. 19Fordy
    19Fordy
  2. Galaxie79
    Galaxie79
    I just called them. They are cast pistons and the kit does not include the timing set or cam kit. Looks like the Flatlander HP kit is the way to go.
  3. Nevala
    Nevala
    The thing is, I'm in it this deep; I want to go with a 4" or 4 1/4" crank. No cranks in those kits.
  4. 19Fordy
    19Fordy
    Make sure the lifters are adjustable. I imagine they are , but make sure. Don't forget to get your rotating ***embly balanced.
  5. Galaxie79
    Galaxie79
    Speedway motors has a 4" **** Crank for $700.
    These **** flathead cranks are made from series 9000 material which is the strongest cast material known. Shot peened, ground and micro-polished to original specs. Uses 1949-1953 bearings.
    • Rod Length: 7.000"
    • Rod Pin: 2.138"
    • Internal balance
    http://www.speedwaymotors.com/****-Flathead-Ford-Stroker-Crankshaft-4-Inch-Stroke,3181.html
    They also have a 4 1/4" crank. Or you can go with a whole stoker kit from them for $1700.
    These 1939-53 flathead rotating ***emblies feature new **** crankshafts, new **** H-beam connecting rods with 2" journals, Ross forged three-ring pistons, rod bearings, and piston rings. The components are balanced and ready for you to ***emble.
    http://www.speedwaymotors.com/1939-53-Flathead-Ford-Rotating-***embly-274-CI,5401.html
  6. 19Fordy
    19Fordy
    I am quite sure that I have read one posting saying that the "balancing" of the **** Speedway Stroker kit is not all that accurate. Have you researched Moldex? Read all this.
    http://www.jalopyjournal.com/forum/showthread.php?t=75490&highlight=****+cranks+balancing
  7. Nevala
    Nevala
    Yeah, you're not going to want to rely on the **** balance from Speedway. You should also include the flywheel, clutch and pressureplate, and even the pulley that you're going to use on the front, for the ultimate balance.
  8. J08h22
    J08h22
    from Minot ND
    Where can I find a rebuild kit at For the that same motor
  9. austinhunt
    austinhunt
  10. TexasSpeed
    TexasSpeed
    from Texas
    Yeah.. It has been a while, hasn't it?
  11. barrnone50
    barrnone50
    from texas
    Its not Odd they have had my Flat motor for about 1 1/2 years. i went up couple of weeks ago and was going to pic it up. Jack said no problem we will get on it right away. LOL They do great work just takes awhile I'am not ready for the motor yet on this project that I am working on going to put a 302. But The A model will need the the flat. Good luck George:D
