First modern project: The Silver Bullet, 92 Crown Victoria
Discussion in 'Off Topic Hot Rods & Customs' started by The_Cat_Of_Ages, May 6, 2024.
  1. ive been doing nothing but working on a 1992 crown vic manual swap for the last 3 months and was curious what the cutoff for off topic is?
    would be cool to share how much ive learned about general drivetrain knowledge here.
    aswell as installing an era correct sound system.
    ffr1222k, scotty t and Sharpone like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    There are no restrictions here for now
  3. pprather
    pprather
    Please share, BIG Cat.
  4. Well, nothing like starting off a thread with a couple miles of pictures, write up, prefacing and explaining. keep in mind, im still not done, fixing cars was definitely easier in high school despite also working. if it werent for my dad saving my *** with a car to borrow id be SOL.
    first things first. why i needed to start this. my daily died from hitting a pothole which dragged the rear axle back, its too rough to fix. i essentially need a whole rear axle, fix the control arm mounts, fix the shock mounts, new brake hoses (again), possibly a new driveshaft, at this point the car is too beat up to really invest 2k into it to get it roadworthy again.
    so i decided to move onto something i bought for cheap last fall. 20240213_165429.jpg
    meet the 1992 crown victoria LX. optioned with a minimal power drivers seat and manual p***enger seat. blue interior, base heater, deluxe radio, etc. has 30k actual miles.
    the oil was changed minimally, every 7k miles. last recorded maintenance i saw was in 1997 (when the still new tires got installed) before the previous owner got it in 2019.
    unfortunately, the tick that i thought was top end ended up being a knock so i sidelined it for a little bit while i tried to source an engine.
    then the above happened.
    within a week i had bought a mustang.
    meet the 2003 mustang owned by some kid 2 years older than me in dayton. he thought he had fashioned himself a drift car. it then reminded him these cars struggle to go straight, let alone make controlled slides. it ate a pole at 50mph. whole car is tweaked, the car was only his for 3k miles, previously old man owned. 20240221_181053.jpg 20240225_175242.jpg
    jacked it up, pulled the driveshaft, transmission, flywheel, and clutch cable. any other parts i need for the swap will be pulled off of it until i s**** it/part it out.
    (my camera is absolutely ruined, by the way)
    below is my parts hoard. i reorganized it later.
    because of the fact I have no idea what "priorities" are i decided to import a one year only radio from Europe because its cooler than the version of it we recieved here. (this will later prove to be an addiction until i got every optional accessory for it, which i did)
    test fitting, unfortunately it didnt come with a trim ring, i will eventually make one for it, its not high on the list.
    drove the clickity clackity 4.6 for the last time up to the slab, 20240319_174804.jpg
    pulled the exhaust off, those cats will be used to make test pipes then promptly s****ped. they are basically plugged so no loss.
    it was a rainy day next so i worked on some other small parts 20240321_124854.jpg
    replaced the wear surface on the aftermarket flywheel, should be a nice new bedding surface for the new clutch. old clutch was pretty badly murdered.
    20240325_174344.jpg swapped out the brakes+wheels and tires for a set of hpps(basically bbs rs) and nice new (2022 mastercraft all season) tires.
    waited about a week before deciding to send it, used a jack and hoist to one person lift the engine and trans out as one piece. 20240326_163158.jpg
    talk about sketch. also it started pouring, this was about march 25th? when you cant work on it every day projects take a long time. but i feel more confident in modifying things. 20240407_155339.jpg
    loaded up the engine and trans and hauled it to the backyard. 20240409_192341.jpg
    converting the column to a manual transmission column, thank god ford uses the same column cast piece for mustangs, vics, rangers, and trucks. 20240413_230336.jpg
    ended up converting my original cluster to a police style speedometer
    and finally the part that has caused me lots of trouble. 20240418_172910.jpg
    this is where my issues with setting up the clutch cable started. i marked too high, drilled too high, and then tried to fix it. im still learning and instead of bending the steel a little bit flatter, i decided to move the hole down a little.
    RRRIP! holesaw tore a chunk from the firewall.
    immediately went and made a patch and braced the area around the firewall with it.
    i will then need to use a piece of 3/16-1/4 in steel to brace the firewall itself.
    ive gotten good at tracing metal, just need to actually weld it, for something like this that is 20 gauge im better off using tiny self tappers in large numbers like the many others who have made this same mistake.
    im out of pictures for this post and i have to be up for work in 5ish hours, youre pretty caught up to how i am currently.
    the reason i dont have an engine currently is partially because im very attached to what would be the donor, and partially because of what i want to do to the motor i put in it. lets just say i want a wee bit more than 190hp 220 torque.
    so im doing a PI swap on an NPI bottom end.
    that increase the compression and flow enough to make nearly 300 hp! (in theory).
    the go fast parts on the mustang would be useful if i didn't realize the previous owner had jacked it up on the oil pan, killing this engine. oh well... i have more plans.
    also i just realized my alliance lapsed, gotta pay the 50 again, good investment!
  5. Sharpone
    Sharpone
    The old Crown Vic’s are pretty much bullet proof guys beat the snot of them around here. A manual in one will be absolutely cool.
    Dan
    The_Cat_Of_Ages and Deuces like this.
  6. i know this wont interest many of the folks here, being all computerey and such. i like old stuff, even if it isnt as old as some of my other old stuff.
    continuing from yesterday, moreso regarding the sound system and less so the mechanicals.
    I was talking with a buddy on a different forum, and he had a video of his cva-1000r, he lives in poland purchased his from a thrift store and pieced it together, and i i immediately knew, i needed to have one.
    he got me in contact with someone who had one that was in box, opened box granted, but nearly 100%. 300 dollars later, (a VERY fair price) 20240224_125752.jpg
    it was a bit of a struggle for the wiring, this is a very advanced radio. luckily this car lacks a p***enger side airbag so i stuck the radios brain there.
    with the DSP im using i wont need speaker outputs, only RCA on the dsp itself, i simply taped up the wires that would be for the speakers. and then connected the front speaker wires to the rear, which will allow me to use the amplifier for the speakers without running new wires for them. over the last couple months i have am***ed a m***ive pile of everything i need.
    the subwoofer(s)
    center speaker (will be mounted in the plenum for the center vents)
    test sizing up the "amp rack" that i got cut out of aluminum. 20240411_155700.jpg
    i found this in a thrift store of all places, a very rare dvd player for my exact system.
    i nearly forgot to mention what amps i am running!
    i sourced a pair of alpine V12 amps from the mid 90s. an mrv-f300 4 channel for the speakers (75wx4), and an mrv-1000 2 channel (will be bridged for 630w)
    the speakers i am running are two front 6x8 2 ways and two 6x9 3 ways. all era correct s series speakers.
    and the final part of this writeup is me replacing the power antenna that got ripped off at some point.
    and that is all, i will be back again next time to talk about the driveshaft, rear axle, suspension, and springs :)
    61Cruiser likes this.
  7. JohnLewis
    JohnLewis
    PI head swap is decent. I'm sure you've probably read into it. Guess the main thing is if your sourcing parts there is differences in the Romeo and Windsor Heads. If you're really going to benefit from it you'll want the PI intake as well. Some small things like brackets, etc are different. I'd try to get everything from one source to avoid mix matching, and I'd get the head change kit. Different models like the vic, f150, etc got the PI upgrades at different year spans so you're not just limited to mustangs. Modular motors are fun.
    The_Cat_Of_Ages likes this.
  8. JohnLewis
    JohnLewis
    IMG_0247.JPG Terrible picture, took me a minute to find it. Work at a shop alittle bit out of dayton off route 4. Kid in a cobra mustang went to p*** a car out front of work and lost it into a pole.
  9. JohnLewis
    JohnLewis
    IMG_2876.JPG IMG_2889.JPG IMG_2890.JPG And a buddy that went under a semi trailer merging onto a dayton highway.
    Deuces and The_Cat_Of_Ages like this.
  10. theres a junkyard near me with a 1999 marquis with 75k miles. and a 2008 crown vic with 82k miles.
    im going to grab the 08 vics intake as theres no sign of it leaking. im grabbing coil brackets off of a 1997 and running the waste spark setup still. by keeping everything crown vic it should prevent issues with incompatibility from popping up. by using the 99 bottom end i will also evade the ****py timing guides and tensioners from later years, and by using the 08 top end i will evade the spark plug chucking heads.
    im also running the 78mm bbk plenum that came with the mustang, a 2004 p71 zip tube and MAF, and doing some slight adapting to the harness of the 92 i can keep the obd1 ecu and have it chipped for a much lower price (435) than swapping to obd 2 and then having it tuned. (would cost nearly 1k! almost as much as a stand alone)
    the driveshaft is getting swapped to my 1993 cvpi aluminum driveshaft, by using a 5/8 spacer on the yoke, and swapping the yoke from the mustangs driveshaft, also swapping to 354 greasable MOOG joints. later this month im driving down to Cincinnati and picking up a torsen limited slip, to pair with my 4.10 rear gears.
    so much for no hot rodding... i cant help myself.
    61Cruiser and JohnLewis like this.
  11. JohnLewis
    JohnLewis
    Sounds like you pretty much have it figured out, good luck in your endeavors. Waiting on the updates.
  12. Kerrynzl
    Kerrynzl
    It is a bit of a shame, but I can see the need for reality. [we are all "aging out"]
    In the last month I've noticed the content has stalled on the main forums, BUT there is a lot of activity in this section.
    Personally [and a suggestion to the moderators] there should be a trail on the cut-off year eg: 55 years and older
    That would now qualify a 1969 or older car
    Hopefully this is only a temporary thing until some new blood gets injected [we need to show encouragement]
    Something we all forget is the perils of time .[and our memories playing tricks on us]
    If we considered 50 years old as a medium age demographic, that person would have been driving to high school at 16 in 1990 [not 1962]
    Ouch!!!
    That is why my daily driver is a Prius "C" [I own the car , It doesn't own me]
    Then I have some toys [for different sorts of "Off Road" experiences]
    ffr1222k and The_Cat_Of_Ages like this.
  13. JohnLewis
    JohnLewis
    Even if all this doesn't work out. I am a fan of a lot of car related content in general. I can see something like this not fitting in well (Understandable). I think the sub forum in general is a great idea in other more year related builds that can't be shown. All over a modern or non-traditional suspension, steering, electrical, etc upgrade or modification and you can't post your build? Or why bother when you have to conceal most of it. Some fine tuning might have to happen but i'm sure not going out to try to find a good flat head ford block and sell my left nut to buy it and have it machined. Ill buy a ls and trans with a harness and drop it into something for a 2 weeks pay check lol.
  14. JohnLewis
    JohnLewis
    Events (edgewaterrace.com)
    Depending when you go down, Edgewater is a little bit out of Cincinatti. Might see what's going on and really make a day of it. If you're ever around the Dayton area, can PM me if you need anything or just around the area.
  15. Kerrynzl
    Kerrynzl
    I'm all for mods that make a car safer and more usable [unfortunately some don't become safer because people get out of their depth]
    This includes Radial tyres, Tandem M/C's , Disc Brake conversions, T5 trans or O/D autos, Sway bars
    Anything that can get more of these old dinosaurs out on the roads.
    Being a suspension and brake person, I think some people should not tamper with steering and brakes unless they really know what they're doing.
    One area where me and the moderators have disagreed on is electric power steering columns [I am all for it]
    The reasoning is we are all aging and the curse of aging [ aka arthritis ] creeps up on some of us.
    Electric power steering columns allows somebody to still use their old car without ruining the steering geometry. Some people should never go near steering geometry at all.
    But if the easy way out is what we are really seeking [eg LS or Coyote swap], then don't bother modify old cars at all. Just buy a modern car like a S550 Mustang or C8 Corvette and jump onto another forum.
    This still is the HAMB not Reality TV [like Chip Fooze]
    The HAMB is all about pedigree . If somebody can disguise a Roller 302 as a 260 , or a Roller 350 as a 283 and put it in an old car then I am all for this.
    I appreciate @Ryan putting the brakes on [even I've overstepped his boundaries and had my fingers smacked ]
    This stops the whole forum running away from it's original intent.
    Here is my old girl
    I've been temped many times to modify it [but glad I haven't]
    61Cruiser, rod1, Deuces and 1 other person like this.
  16. JohnLewis
    JohnLewis
    Very nice car, and I am with you on a majority of what you say. I'd hardly say a ls or coyote swap etc, is the easyway out. Any type of motor swap presents its own challenges, especially when you get into more electrical and computer controlled products. I'm not saying i'd buy a car and swap a ls in because I can. There's plenty of older motors I'd rather build and are building. I'm not buying or agree with buying a older car with a perfectly fine or rebuildable motor and just dropping a ls in. But if I buy a 50's chevy roller and my choices are going back to a inline, doing a sbc or a ls drive train. Anymore right now for cruising, reliability, affordability, etc. I'd honestly rather do a ls.
    . Think I find more Enginuity in a ls or modern swap than I do in a sbc swap everyone else in the world does.
    "But if the easy way out is what we are really seeking [eg LS or Coyote swap], then don't bother modify old cars at all. Just buy a modern car like a S550 Mustang or C8 Corvette and jump onto another forum."
    Find it alittle hypocritical since both those cars come with everything you mentioned as upgrades, But it's the easy way out to put a modern motor in a standard ch***is with none of that? I'd think if you put any motor in one of those two cars you wouldn't tell the difference rideability wise just as if you put a modern motor in any old ch***is.
  17. gene-koning
    gene-koning
    The hard reality is, its getting much harder to get any motor rebuilt these days. With the recent down turn in quality of flat tappet lifters, rebuilding any non-roller cam motor got even more difficult. Its not the old days where you can take your stuff to a machine shop and pick up a rebuilt motor in a couple months, around here its a year before you can even bring it in, and if its not a roller motor, they won't touch it.
    The car hobby has changed a lot over the last few years. Hot rod ownership crosses many lines today. Trying to fit them (us) into any little box limits how much participation we will (or can) become involved with. Personally, I have never fit very well into any "car" box. I love the old body styles with modern drivetrains, but even those old body styles have become limited by my not well taken care of, and aging body. I don't fit well into those vehicles much older then the 1940s, as much as I do love some of those older styles.
    How about as this off topic part of the HAMB plays out, we enjoy it as we ride along. How about we all try not to put limitations on what can or can't be be here? If we just check out the stuff we like, skip over the stuff we don't like, and we all be civilized about it, maybe we can attract a much wider group of people and hot rods.
  18. SS327
    SS327
    What colors is this old girl? She looks sharp!
    Deuces, JohnLewis, rod1 and 1 other person like this.
  19. Kerrynzl
    Kerrynzl
    Sierra Gold with Adobe Beige roof
    Here's another photo with my "better half" posing.
  20. Kerrynzl
    Kerrynzl
    The hard reality is ........... Getting a suitable car for a project [our cut-off year was 60 years ago]
    Which I am all for preserving an era .
    But I am probably the most guilty of "sleight of hand" as anybody [disguising new engines as old etc]
    But as the perils of time creep up, these old hot rods start getting accepted along side vintage cars
    Cars like my 57 were stock in 1957 ,it probably took until 1967 before they got cheap enough for people to modify them [during the flower power, summer of love era ??? ]
    JohnLewis and The_Cat_Of_Ages like this.
  21. from everything ive read, cars lost value much faster than they do today.
    RFovwsScELgpWHF_wxk9kw-wWiXV1tHDy5HwNhIqEWM (1).jpg look at this picture, the newest car i see is a 1960ish ford falcon, these cars are barely 6 years old and already less than a hundred dollars
    ffr1222k and rod1 like this.
  22. gene-koning
    gene-koning
    Back in the 50s, 60, and early 70s, a 3-4 year old car was considered an old, very cheap, back row car. When almost none it to 100,000 miles, a car with 60,000 on it was pretty wore out. There was a very good reason they made turning the vehicle mileage back illegal.
    My 1st job was pumping gas and doing service work at a gas station (started working there in 1972). That gas station was one of the highest volume gas selling places in our town and had 3 repair bays. Back then, I could count the cars that came into that station that made it to 100,000 miles on one hand, out of probably 10,000 cars in the town at the time.
    My 69 Buick I bought in 73 was 4 years old with 49,000 miles on it. I bought it without a trade in for less then a $1,000 at a dealership. Gene's life line scaned pictures 001.jpg
  23. ekimneirbo
    ekimneirbo
    from Brooks Ky
    My suggestion is to limit it to 2000 (so only cars from the last century are allowed, but any engine is acceptable as long as it burns fossil fuels.
    The_Cat_Of_Ages and JohnLewis like this.
    got an engine last week and started immediately pulled it apart, after stripping it down to the short block i went through and checked tolerances, all within spec.
    so i went and pulled the mustangs heads and timing cover, this was a running issue free car so id like to use the relatively new timing components and belt components i also went and picked up some coil pack brackets. once this is together i'll need to run the fuel pump on the car into a can to drain all the 87 and refill with 93. then once i verify it runs, send the ecu off to Mo's speed shop and have it tuned.
    this engine is at 75k miles so it should last me at least 100k.
    61Cruiser, ffr1222k and JohnLewis like this.
  25. update on this project.
    reason ive not been working on this or the 57 is that im building a far more serious engine. debating on selling this 2v to someone else for money to build my dream engine.
    got nearly all the parts.. just like 2k more and i'll be able to ***emble it.
    its a 1996 cobra 32v with a vortech supercharger, going to push 16psi through it with a water-air intercooler. if i build it right i should hit 650 wheel horsepower without much issue.
    the parts list:
    2003 Mach 1 Forged crank,
    2015 mustang gt forged rods,
    1996 cobra heads ported and polished by mhs with stainless valves,
    1996 cobra intake manifold
    1996 cobra front cover
    1996 cobra wiring harness
    2003 explorer aluminum block,
    vortech v3 supercharger.
    the remaining parts
    Cloyes timing kit,
    manley forged pistons,
    vortech power cooler water air intercooler.
    ARP hardware.
    machine shop work.
    and many other nickel and diming things.
    SS327 likes this.
  26. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    If my opinion means anything, I like the free for all rules here so far. This is the only place on the internet I still post and that's because of the quality of the people , the knowledge of the people, and the moderation. I trust the info I get here a hell of a lot more than anyplace else on the internet.
    Seems like we're all here because we either own or have a p***ion for traditional hot rods, and if we need help from time to time with our other OT stuff, as many of us have automotive interests that expand beyond the traditional hot rod, again, I trust the knowledge here more than anyplace else.
  27. changed the ***le from "How new is too new?"
    update on the last post.
    I've spent 1200 of that 2k I said. I was wrong, its gonna be more like 3k, damn cars are expensive.
    I've also decided I'm changing to e85. 80 lb injectors and bumping up a size of fuel line, and a big boy external pump with a pump basket delete, should be safe to hit 700hp with this setup. 650 is the goal.
    i tried to save a few bucks with used pistons, got jipped and didnt tell me that the pistons were from a blown engine, if i buy rings and get them recoated itll cost more than if i just bought new. so new it is, i can sell these for a bit to make back my money, along with my 60lb injectors.
    also found my air-water intercooler, all thats left is the belt, reservoir, heat exchanger, and a rebuild and the kit is complete for around 2300 total, 5k less than most kits for similar cars by just doing it piecemeal and biding my time.
    also need oil pump and 8 rib pulleys for a v10
  28. oldiron 440
    oldiron 440
    I think your project is cool and represents hotroding in its truest form from the beginning of the hotrod. Find an old cheap body and then build it the way you want it to be, more performance etc. I think the manual transmission is a hit and I’m looking forward to seeing what else you come up with.:)
  29. so many people outside the circle of this car poke at me for choosing a full size bof car to modify.
    its no different than choosing a full size ford vs a t bird or galaxie vs a mustang back in the 50s and 60s.
    some people want a more sizable car, and to make it silly fast.
    jimmy six and porkshop like this.
