Projects First paint job
Discussion in 'The Hokey Ass Message Board' started by Grabis, Sep 26, 2017.
  1. 61Cruiser
    61Cruiser
    Looks absolutely awesome. Great work[emoji106]
    Grabis likes this.
  2. Nice job!
    Grabis likes this.
  3. warhorseracing
    warhorseracing
    from cameron wv
    Much better. Practice does help.
    Grabis likes this.
  4. Technically that would now be your second paint job, right?
    Grabis likes this.
  5. tb33anda3rd
    tb33anda3rd
    nice job.
    Grabis likes this.
  6. It turned out nice.Here was my 1st paint job way back when I had my small shop. Of cause the snow didn't help it, and I had more hair back then. LOL. Bruce. img703.jpg
    Grabis likes this.
  7. The last paint job, I did in my garage. I did it with a H.F paint gun and like Grabis says it has to have a regulator on it .Mine did, made a big difference. Bruce. 001.JPG
  8. mcmopar
    mcmopar
    from Strum, wi
    When I cut and buff, I leave the car taped up if I do it right away, seems to save time on cleanup. The buffing compound turns into a rock if not cleaned up right away.
    Tony
  9. tb33anda3rd
    tb33anda3rd
    i have found that my hvlp gun never shot "right" until i took the regulator at the gun off, and replaced it with a regulator at the wall. i think the one i had was good at the LP part but was restricting the HV part.
  10. Grabis
    Grabis
    Yes, I went into it with 100% more experience under my belt haha
    Cliff Ramsdell likes this.
  11. Grabis
    Grabis
    Good idea, If there was anything besides a milk crate inside I would have ripped the paper off and went for a cruise. That crate slipped backwards on me when I was trying to drive it into the garage. I think I puckered so hard I held onto it long enough to brake.
  12. Grabis
    Grabis
    Hadn’t thought about regulator flow. I’m using all cheap stuff right now. I’d like to change the setup anyway and maybe get a regulator intended for a gun. I have this one running a regulator and dryer/filter off the bottom and the hose hit the floor when doing the lowest part of the car.
  13. tb33anda3rd
    tb33anda3rd
    those in line dryer are a restriction also. when i bought my hvlp they sold me a 1/2 air line to feed it. i sprayed with the regulator at the gun for a couple years and never even thought it would have been a problem till i set up my new shop with the regulator at the wall. it was like a whole different gun.
  14. I swapped the fitting on my gun to 3/8 and it made a huge difference by providing more volume. I might try the wall regulator and see if it gets any better as there's a bunch of restriction in those pissy little valves. Also I sorta made a mistake while cleaning my gun and reamed the holes in the cap next to the nozzle. I thought I screwed up the cap but it sprayed a lot better after that.
    tb33anda3rd likes this.
  15. gimpyshotrods
    gimpyshotrods
    I use Milton V fittings. They are bigger inside, and flow a disturbing amount of air.
    jazz1 likes this.
  16. Your Chrysler came out nice Bruce. Happy Thanksgiving to you and the family Bruce.
  17. Grabis
    Grabis
    My stepdads 58 is heading off to have the headliner and windlace installed. First time it’s been out of the garage since I painted it last November. Nice seeing it outside even in the gray and rain. Perfect timing too. Just got a notice from the county that I have to do something with my derelict cars or I’ll be fined $100 a day. I have to 54s with no front sheet metal. They’re both rollers. Sheesh. At least the garage just got an open spot. [​IMG][​IMG][​IMG]
  18. ThisOneGoesTo11
    ThisOneGoesTo11
    from Oxford, PA
    Great looking car. That $3000-7000 you saved him will buy one nice headliner...
