first rollout for my new go-cart? fodge?
Discussion in 'The Hokey Ass Message Board' started by Justin B, Mar 21, 2007.
  1. Justin B
    Justin B
    took alot longer than i had planned between customer cars and being sick for a few weeks but i finnally got it to the point where i could roll it out of the garage for the first time. i wanted to do a car like a shifter cart, only the essentials, short wheel base, low, more than enough power, etc. wheel base is 95 in. and its about 4.5 off the ground at the lowest point. still having some major issues with the rear spring and the shop that fucked me on it (i had them narrow it and they didn't retemper it and won't admit it) i'll just end up having a new one made at a different shop and throwing this one through the origional shops window.
    anyways here are a few pics
  2. 327-365hp
    327-365hp
    from Mass
    That's looking cool man! But what's a fodge I thought it was a Dord
  3. roosters hot rods
    roosters hot rods
    looks like it gonna be FAST........bitchin.......rooster
  4. Imwalkin
    Imwalkin
    from Tucson, Az
    nice!!! What are the wheels?
  5. Anderson
    Anderson
    that car is amazing. perfect....
  6. G V Gordon
    G V Gordon
    from Enid OK
    Wheels, Early MOPAR? correct?
  7. Justin B
    Justin B
    i think it's a fodge since the cowl is ford and the back is dodge, if the cowl was a dodge and the back ford then it'd be a dord :)
    i'm not real sure what the wheels are, i've run two different styles of the dodge artilleries on other cars and if these are dodge they're earlier than the other ones i've used which were 34's and 36-7's, these are also 17" instead of 16" and made by motor wheels corp of lansing mich. i've tried the early dodge, chevy and ford hupcaps on them and nothing fits. the 32 ford stlye cap fits the hole perfect but the inner part where it locks in place is to small, i think i'll end up using them just have to figure out a way to attach them to the wheel.
    oh yeah we also finally got the essex body back on the frame for the last time this week
  8. alsancle
    alsancle
    I dig the artillery wheels and the quick change. Very cool.
  9. 31aBoy
    31aBoy
    What year is that essex? Got any extra headlights or grill you'd like to get rid of?
  10. Justin B
    Justin B
    the essex is a 28, i think, at least that what the title said that came with it. i don't have any extra essex parts but i do have a hudson grille of around the same year, looks the same as an essex but is about an inch taller and wider, plus it has a winterfront insert.
  11. I really dig the side-view.
    Great proportions.
  12. so how deep is your trans tunnel? like an arm rest or not
  13. OLLIN
    OLLIN
  14. That is awsome, you got any interior shots, i too am curious of the tunnel
  15. Roadsir
    Roadsir
    Very similar to what I am thinking for my '27 Roadster...
    How much kick-up in the rear....15"?
    What about pedal assy, and steering plans. I would be interested in seeing an interior shot as well.
    Nice job!
  16. sweet litle "go cart" you got there
  17. Doodlrodz
    Doodlrodz
    Very nice, love the stance.
  18. I like it. Have you thought of chopping the grill shell?
  19. I really like the angle of the windsheild frame, they usually go to far over the top of the cowl, and are laid back too far in my opinion. I'd like to get one for my home-built roadster pickup, and do away with the existing sedan posts. My only concern is that the middle post seems to be at much more of an angle than the ends. Will the glass have to be twisted somehow, or am I missing something?
  20. AnimalAin
    AnimalAin
    Very neat hot rod. Keep us advised as you progress.
  21. Justin B
    Justin B
    richardd the windshield was kinda a weird deal, a friend up the street works at a place that makes dna lab test equipment out of lexan, they had just got some new stuff that is supposed to be harder than glass to scratch but still easily formable with a little heat. the windshield frame does have a little twist to it to keep the glass (lexan) from coming back to far, it's angled more at the center than at the ends and has a curve through the middle, it's going to be a test to see how this lexan works. i might not even run the windshield frame on this car since i'm going to use the stock gas tank it will be a little hard to attach it from the bottom, might just save it for the next project and build one out of steel that i can weld right to the top of the tank. here's how i made the windshield http://www.jalopyjournal.com/forum/showthread.php?t=143053
    here's an interior shot, the tunnel actually isn't to bad, it sticks up about 8in. off the floor but with a 3-4in. cushion it's not in the way and acts like a wrap around seat that will hold your ass in place. this was another reason for the quick change rear, the pinion is lower than a regular rear so the tunnel doesn't have to be as tall.
    i will be shortening the grill shell also, as it will run a hood top
  22. CGkidd
    CGkidd
    That interior is cool. Oh hell the whole project is cool.
    Eric
  23. retroridesbyrich
    retroridesbyrich
    from Central NC
    Modifieds are my favorites and that one is the cat's ass! Great job!
  24. kustombuilder
    kustombuilder
    from Novi, MI
    LOVE it!! it's got a great stance and overall shape. should be a fun little car.
  25. chevychris5
    chevychris5
    Looks the buisness keep the flame burning bright, Safe Cruisin, chris
  26. Scott
    Scott
    Can we get a better look at the rear suspension set up.
    Man I like that car
  27. I'm a big Fodge fan....looking for decals. :)
  28. El-Cid
    El-Cid
    Wow, this car really strikes a chord. It's the right combination of size, stance, wheels, etc. I'm looking forward to a full blow-by-blow.
  29. Justin B
    Justin B
    worked on it a little more the last couple days. made the headers, started on the hood, and made a new steering wheel for it.
  30. Make sure you wipe it clean first
