Hot Rods First year Y Block pulley removal question
Discussion in 'The Hokey Ass Message Board' started by Kickstarter, May 15, 2019.
  1. Kickstarter
    Kickstarter
    from NC
    Whats the best way to remove the crank pulley on a 239 Y Block. It appears to be pretty thin and a three jaw pulley remover looks like it will damage it.
  2. are they not the same as the newer Y blocks? I just use a puller that uses three bolts to pull with but that is on a 292.
  3. Kickstarter
    Kickstarter
    from NC
    No they are different, almost looks like its sheet metal, the latter ones are cast and much heavier.
    46international likes this.
  4. will the later ones interchange with the early stamped type?
  5. Kickstarter
    Kickstarter
    from NC
    I'm not sure yet, I've got one if they will.
  6. Never use anything but a puller that bolts to a harmonic balancer for removal. You will remove the inertia ring with a jaw puller. Make sure you remove the washer behind the bolt before connecting the puller. You may need a spacer for the end of the crank but it has to be smaller than the crank snout.
  7. Kickstarter
    Kickstarter
    from NC
    There is no way to bolt to this one, it's a stamped metal pulley.
  8. miker98038
    miker98038
  9. I did one a few weeks ago,
    I used a tool that had two arms with "hooks" on the end that you placed inside the pulley and they hooked outward into the small slots in the pulley, then you attached them to a cross bar via bolts, then thread a large bolt down the center of the of the cross bar and tighten until the pulley slips off the crank. I did have to add a "spacer" (old socket) to the bottom of the center bolt to get it to pull all the way off. It was fiddley to assemble inside the pulley center but worked like a charm... sorry I didn't take any pictures of the tool.
    FWIW the engine was out of a 56 T-bird.
    here is another option... page 57, part TL7.
    https://www.classictbird.com/pdf/CASCO-webalog.pdf
    Chappy
  10. Kickstarter
    Kickstarter
    from NC
    Thanks! Maybe I should have titled this, Blue Hot Rods. LOL then it might get something.
  11. Kickstarter
    Kickstarter
    from NC
  12. Kickstarter
    Kickstarter
    from NC
    Was your pulley cast?
  13. Kickstarter
    Kickstarter
    from NC
    Ended up putting a board behind the pulley and lightly prying out on it, it didn't take much and it popped right off. Now to swap out the timing cover and see how it fits in the 50 Shoebox.
