Fitting Model A Radiator: Hits Fan!!!!!
Discussion in 'The Hokey Ass Message Board' started by KANE MCAFFER, Sep 24, 2012.
  1. elmitcheristo
    elmitcheristo
    Yes, the straight edge is laying flat against the firewall. Just another thought. but if you are using an "A" frame you could use the side motor mounts to give you an approximate location. Even if they aren't there, you would still have the bolt holes.
    Just a thought,
    Mitch
  2. Working Class Zero
    Working Class Zero
    Mitch, appreciate that. Mine is about 3/8 off that same driver's side head nut. But as I said when I put on the front original A mount it lands dead center in it's front crossmember hole. Weird!!!
  3. Working Class Zero
    Working Class Zero
    There must be some variation from car to car on this without causing a problem? like an 8th her or there no? Once I brought the motor up on the jack to fit the front mount I seemed to gain some clearance. Now at about 3/8 fan nut to rad. The oddity also is the starter. When this motor was in the AA the starter rod dropped right into place, on the rod it is out, and I can manipulate it by removing the housing on top of starter, putting in rod first then replacing housing, but this seems wrong........
  4. Working Class Zero
    Working Class Zero
    I'll try to post up some pics........
  5. Working Class Zero
    Working Class Zero
    Ok Pics.......
    Let's start with one to get us excited about what she will look like. Thanks for the headlight mock up girls!!!!!
  6. Bruce Lancaster
    Bruce Lancaster
    Hmmm...post #63...seems to be raising an angle problem. A motor mounts at a pretty steep uphill pitch, which of couse pulls fan hub away from radiator.
    Have you put a level up against the stock manifold carb flange??
    Right now I'm looking at a side view in the old ****'s manual. Picture seems to show '30-31 radiator...at the pitch shown the fanblade tip at top is at least 4 times as far from radiator as the one pointed down.
  7. Working Class Zero
    Working Class Zero
    Ok, down to business. Here is a picture showing the front A mount. Lines up nicely with the crossmember hole. Looks odd in pic but trust me its bang on.
  8. Working Class Zero
    Working Class Zero
    oops, here is the crossmember pic........
  9. Working Class Zero
    Working Class Zero
    Yes Bruce!!! with the motor jacked up now, the fan is exactly as you stated. Fanblade tip at top is at least 4 times as far from radiator as the one pointed down.
  10. Working Class Zero
    Working Class Zero
    Here is a shot at the firewall..........
  11. Working Class Zero
    Working Class Zero
    5/8 clearance at top blade
  12. Working Class Zero
    Working Class Zero
    3/16 bottom on blade
  13. Working Class Zero
    Working Class Zero
    3/8 at fan nut
    However shaft has a 16th of forward play making it 5/16
  14. Bruce Lancaster
    Bruce Lancaster
    Pull that pump, remove impeller and slide it forward and repin on shaft, grind off any excess length at rear?? Anyway, look over Bratton's catalog...it's been a while since I had a pump apart. They sell a collar for killing off end play in the A, and all A innards are the same as '32 B except the impeller. Kill the endplay, and of course add '32 type steady rods so engine cannot move forward.
    (From memory, I think endplay stock is controlled by impeller one way, that socket in head the other way. Said socket is often worn and rusted away, and shaft is repro of dubious precision, so the sftermarket collar is used to add an endplay stop at front of shaft.)
  15. Working Class Zero
    Working Class Zero
    I see where the steady rods go thru my 33 34 bell housing however I wonder how they land on the k member? Looks as if they would land on the angled part of k member yet the rare and only pic I have seen of the rods have non angled plates that bolt on.... Where can you get these? Or do I just make em?
  16. MATACONCEPTS
    MATACONCEPTS
    Dude, your trippin. Listen to Bruce Lancaster. Work that pump over. Bend the blades slightly. Get some room out of the radiator mounting holes. Start driving it ese.
  17. Working Class Zero
    Working Class Zero
    And what are you thoughts on my current fan clearance and firewall distances? Besides fixing impeller issue of course. Still different it seems from Brent for instance....
  18. MATACONCEPTS
    MATACONCEPTS
    Make em. Move forward. Put it behind you.
    They hold the torque to the ch***is, so they would be better pulling on a K member that's more paralle than perpendicular to.
  19. Working Class Zero
    Working Class Zero
    Haha. I know!! I always listen closely to Bruce! He knows his stuff and is always willing to go out of his eay to help. Don't know bout bending blades though......
  20. Bruce Lancaster
    Bruce Lancaster
    http://www.jalopyjournal.com/forum/showthread.php?t=736842&highlight=rods covers '32 rods. '33 are spaced a bit differently but you should be able to come up with something. Rods can go to FRONT xmember, too, if that works, or you can ream out a bellhousing hole...
    I would not speculate further on current spacing without a stock Model A handy for reference. Remember Model A bellhousing mounts are effectively entirely rigid, so there is no forward play .
  21. Working Class Zero
    Working Class Zero
    They hold the torque tube to the ch***is? Huh? I thought they stop the motor and Trans from moving forward and aft by pinning it to the k member?
  22. Bruce Lancaster
    Bruce Lancaster
  23. MATACONCEPTS
    MATACONCEPTS
    I did a quick engine switch about 2 months ago, I put a 4 blade on, started it & it was hitting, a slight tweek & drove it to work everyday for about a month, the blade did break the spot welds from the pulley but the pump had about a 1/2" play I neglected to re-pack. I think the 1/2"play caused it to break. I might weld it back together . . . Na, the two extra blades were slowing me down.
    Take the rad off & grind the shaft & nut down. It only metal Johhny. Let go cruising.
  24. Working Class Zero
    Working Class Zero
  25. MATACONCEPTS
    MATACONCEPTS
    Go forward to the front or to the side rails, which will help prevent fan/radiator conflicts. Maybe and another suplimental front crossmember under the crank pulley.
    Dont think too hard, but think outside the box. Kind of ironic, huh.
  26. -Brent-
    -Brent-
    Here's what I've found out...
    AA radiator is 2 5/8" and my radiator (stock) from a car (based on the running boards) was 2". So there's that solved.
    Also, the distance from the nut on the fan and the radiator is nearly 1". Mine has a little rash from hitting said nut. I don't know how, or under what conditions, but the evidence is there.
  27. Working Class Zero
    Working Class Zero
    As for putting the motor at the correct angle, I should do so by seeing that the carb flange is level? Is this a good method? If so level with ground or frame rail? Truck might have a slighy angled stance, lower in front, when done......?
  28. Bruce Lancaster
    Bruce Lancaster
    Here's the alignment point! Slide the handcrank in; if it doesn't go into the socket on crank, the motor is in the wrong place. You can improvise with a rod of some kind through rad shell and spring mount if you have chosen AAA over the handcrank.
  29. Working Class Zero
    Working Class Zero
    Good call Bruce. Thanks. Man I'm stupid sometimes.
