Technical Fitting size
Discussion in 'Traditional Hot Rods' started by dirt t, Sep 1, 2025.
  1. dirt t
    dirt t
    What size fitting is this ? I want it with an6 for the fuel pump.
    Thank you
  2. squirrel
    are you asking about the hole in the pump? looks like 1/2" NPT?
  3. dirt t
    dirt t
    This has the correct thread's but doesn't seat.
    Terry aka dirt t
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    I am guessing 3/8 NPT if the caliper was used to measure the hole?
    that flared fitting will not seat, those are NPT
    deathrowdave, warbird1 and 1oldtimer like this.
  5. dirt t
    dirt t
    It's a 454 chevy.
    Also Squirrel once there's positive manifold pressure what happens to vacuum advance.
    Thanks for helping. This is nothing like my TAFC that was easy. Lean until egt got to 1200*
    Terry aka dirt t
  6. dirt t
    dirt t
    Thanks moe
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    there will still be vacuum at the carb because it is above the blower. hook the vac adv to a port on the carb
    don colaps likes this.
  8. dirt t
    dirt t
  9. dirt t
    dirt t
    Will that vacuum operate turbo 350 also
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    it should, @squirrel has more practical experience with blowers
  11. RmK57
    RmK57
    That looks like a flare fitting…3/8”? I’d say you need 3/8” male pipe to 3/8” female inverted flare to make that tube usable.
    Cleveland Coupe likes this.
  12. squirrel
    hmmm....vacuum controls like advance and shifting are best NOT connected to the carb. Because when it's making boost you do NOT want vacuum advance, or modulator vacuum.
    The best answer is use a mechanical advance only distributor, and a manual shift transmission (such as a Th400 with a manual valve body). I played with both vacuum things with my 55 for years with the blown 454, but when I built Plan II, I went full manual/mechanical, and it worked better
    warbird1, 427 sleeper and Moriarity like this.
  13. squirrel
    Oh...yeah, this is probably the fitting you need.
    theHIGHLANDER likes this.
  14. DDDenny
    A little sumpth'n sumpth'n.
    Just Gary and warbird1 like this.
  15. dirt t
    dirt t
    The caliper measured opening.
    Looking to use an an6 fitting. Mo
  16. dirt t
    dirt t
    Thanks u guys.
    Terry
    Aka dirt t
  17. Fordors
    Fordors
    Before you buy a 3/8 NPT to -6 fitting try taking that fuel pump to the local hardware store and see if any 3/8 NPT fittings fit. Both the 3/8 tube fitting you showed and a 3/8 pipe fitting have 18 threads per inch but I think the pipe thread will not screw into the pump.
    Here’s a 3/8 tube nut screwed into its 5/8-18 threaded hole^
    This 3/8 NPT x -6 AN fitting has 18 threads per inch like the tube fitting but its diameter is greater.
  18. Fordors
    Fordors
    Not cheap but I think this does the job, my very old Earl’s catalog shows it as item number ES 8490-6-6, Holley uses a new numbering system as shown on the photos.
    This looks like it will work, maybe someone else will comment.
  19. 57tailgater
    57tailgater
    from Georgia
    If you were measuring the internal threads on the pump, you must be aware you were measuring approximately the minor diameter of the thread. For a -6 (3/8) nominal size for both JIC (AN) and inverted flare is .563" which is close to what you measured. If it's a pipe thread, the diameter measured will depend on where you measure it at as it tapers down as you go inward. I don't see a seat for an inverted flare like what is shown in the pic of the fuel filter posted. If it is a straight thread and the surface around the hole looks machined (not just a cast surface) it may be a straight thread o-ring style like the one shown in the last post. It also almost looks like there is a small recess machined in there too (hard to tell by the pic) which would be to accommodate the o-ring. The threads will be the same size as the JIC (AN) style for a -6 size of 9/16-18.
  20. 19Eddy30
    19Eddy30
    from VA
    by pic , fuel pimp looks to been cut for O ring , if so JIC ,
    Some Pipe , some Jic A/N
    How is your 350 built & what mods?
    If not correct , you will need to look into this or one like it .
    & you will need to Not run Vac Avance
    Any thing above rooter going to pull vacuum,
    Theres ways to make work , requires thinking to do I honestly do not think nobody makes the part at least how I would do it.
    Below rotor vac , & Spring loaded popet check valve
  21. squirrel
    I modified the BDS PDV, and got it to kind of work...I set it up so it would supply manifold vacuum to the modulator, until it started making boost, then it would provide atmospheric pressure.
    but you could try just connecting the vacuum hose to the intake manifold and see how it works.
    You can also put a vacuum gage between the carbs and blower, and a vacuum/boost gage at the intake, and see how the numbers look. Keep in mind that if you're making boost, and the modulator thinks there's vacuum, it will not be boosting line pressure enough to keep the clutches from slipping. Have fun.
    seb fontana likes this.
  22. dirt t
    dirt t
    Thank's for the reply.Terry aka dirt t
  23. leadsled
    leadsled
    That looks -6 inverted flare too me. Does it have 5/8" -18tpi?
    -5 inverted flare is 1/2" 20tpi
  24. leadsled
    leadsled
    3/8" NPT is also 18 TPI but .675" OD
  25. leadsled
    leadsled
  26. leadsled
    leadsled
    I think you want a speedway P/N 6174033.
    1/2 20 IF male to -6 AN male
    double verify with a TPI gauge and you calipers
    19Eddy30 likes this.
  27. Mr48chev
    Looking at that style of fuel pump on Jegs site the ones I looked had pipe threads in the body.
    If it doesn't have that seat for the flair on the tube to seat on it is not a flair fitting. You can usually distinguish the taper on pipe threads. D Denny's post #14 is something that a lot of us should save to the reference file. Plus pipe fittings are measured by the ID of the pipe not the OD of the threads. Screenshot (577).png
  28. 31 Coupe
    31 Coupe
    Definitely looks like an "Inverted Flare" fitting ..... you can usually buy IF to JIC(AN) steel adapter fitting from hydraulics suppliers. I use them regularly to convert fuel, transmission, PS connections to JIC(AN) male.
    This is a sample fitting from SUMMIT, they have a wide variety of sizes and materials etc.
    https://www.summitracing.com/parts/aer-fbm2964
  29. dirt t
    dirt t
    Thank you for the replies.
    Ain't the HAMB great.
