Technical fiulsender access '32 roadster
Discussion in 'Traditional Hot Rods' started by oldbanger71, Apr 2, 2019.
  1. oldbanger71
    oldbanger71
    Hi guy's, i wondered how you made access to the fiulgauge-sender through your '32 roadster trunkfloor, pictures and mesurements are very wellcome. Standardtank that is..
  2. pprather
    pprather
    Unbolted the spreader bar, unhooked fuel line, etc. Slid tank out the back. Not that difficult when the tank is almost empty.
    Phil
    clem likes this.
  3. alchemy
    alchemy
    If you are going to do the unbolt and slide method, make sure to leave enough slack in the wiring for the sender. Or a connector plug in an accessible place.
    pprather and clem like this.
  4. LM14
    LM14
    from Iowa
    Here’s what I did on my coupe. Had to put a hump in it to clear one of the fittings.
    SPark
    595A6262-8163-4148-96AA-82330A80E9C3.jpeg 6C548651-6DCD-4C0D-ADF1-7006281CAF65.jpeg DD9E8D65-6BB7-400E-849D-0624F63B1D41.jpeg DC67C681-9A06-4793-807E-851C022A7BC9.jpeg
    dwollam and mgtstumpy like this.
  5. hotrodA
    hotrodA
    Not a Roadster, but the stock floor pans had an opening and cover.
    I also put extra length hose and wire so I could access it by pulling spreader bar and sliding tank to the rear.
