FIXING out of round tires
Discussion in 'The Hokey Ass Message Board' started by VA T, Aug 26, 2011.
  1. VA T
    VA T
    I am re-posting "out of round tires" as a lot of us have been dealing with unsafe, out of round, small 16" tires. Here is a solution that can be done at home with some preparation, an angle head grinder, and 36 grit grinding disk.
    Using a piece of 1 1/4" solid round, 22" long, I threaded 15" (12 tpi) on my lathe and made round nuts to match. Other end was stepped to fit early Ford spindle king pin boss and threaded for standard unf nut. Using heat and vice bending blocks, a 12 degree bend was done to make round stock run parallel to hub face.
    The angle head grinder saddle was made from pipe and thin curved plate with plate angled 84 degrees to pipe. Don't weld solid until you are satisfied with alignment to tire tread. Two or three hose clamps secure grinder to saddle.
    Grinder handle extension was made from bicycle tubing, s**** plate, and redi-rod. Extension helps control of grinder and your shoulder muscles will thank you.
    I take high spots down by rotating tire back and forth and eventually letting grinder rotate tire while gloved hand controls rate of turning. The best thing about this process is you remove a minimum amount of tread. You don't have to "bury" a cutting wheel to maintain an even cut. The 36 grit disk does a fine job of leveling tread irregularities.
    After four years of tedious low speed driving, I can drive my home built roadster at normal highway speeds!!! Even trued a cupped 15" radial tire on another vehicle--it now drives like new. THIS REALLY WORKS.
    I am interested in comments and suggestions for improving this process.
  2. c-10 simplex
    c-10 simplex
    Very good, keep it coming. i've been looking for a tire shaver for years. i think tire shops eschew them because there's no profit(very small profit) in shaving tires vs. telling the customer "they need new tires," "there's no way to fix this." etc. and selling a brand-new tire.
  3. VA T
    VA T
    Here are a couple more pics.
  4. badshifter
    badshifter
    Looks good, and scary at the same time! I like it. Does it just grind them flat, or does it make a crown on the tire?
  5. VA T
    VA T
    Try again for second pic.
  6. VA T
    VA T
    Actually it is not scary. It will grind a crown.
  7. alchemy
    alchemy
    Might be smart to warm the tire up on the road, then take it off warm, to remove any flat spots it got from sitting with weight on it. If you are doing new, freshly mounted tires, then don't worry about it.
  8. derbydad276
    derbydad276
    thats 1 hell of a mouse trap
  9. temper_mental
    temper_mental
    from Texas
    The only question I have is how much are you gong to charge to fix out of round tires? With some changes you could also grind white walls.
  10. toolman1967
    toolman1967
    Cheap simple fix....You Da Man!
  11. Bar Ditch
    Bar Ditch
    from Tacoma
    That just made my day.LB
  12. VA T
    VA T
    Thanks, Alchemy. I forgot to mention driving out the flat spots.
  13. Rem
    Rem
    I like that.
  14. Von Rigg Fink
    Von Rigg Fink
    from Garage
    just throw em on the car and do a nice long burnout....same deal right?..but way more fun
    if the ones out of round wont fit on back, then i guess you have this to play with
  15. dave lewis
    dave lewis
    from Nampa ID
    How about some pics of it in use ?
    Dave
  16. 35mastr
    35mastr
    from Norcal
    Yes,I want to see that thing in use also.
  17. PG
    PG
    Super rad! We have a truing machine at our shop. Yours looks like it'd probably do a better job and a cleaner one too.
