Fkathead distrivutor help
Discussion in 'The Hokey Ass Message Board' started by Redbows35panel, Jun 8, 2011.
  1. Redbows35panel
    Redbows35panel
    My 1938 Ford flathead refused to start yesterday. Problem no spark. Upon researching I found that the little spring *** that goes from the coil to the points was melted. Now here is the problem. Sometime someone as installed a conversion to a regular type coil on it. There is a plate that bolts where the original coil was in the top of the distributor that resembles the bottom of a regular coil. Little spring *** with the condenser and secondary winding wire attached and the tower like rotor terminal where the high voltage wire from the coil attaches. I can find no reference to this type of conversion anywhere,. I'd like to replace the part if I can find it. Any one ever seen this type of coil conversion and where did it come from? Where can I buy replacement parts?:confused:
    OK! now that I got the pictures posted. What caused the spring *** to melt. I do not see a ballast resistor anywhere nor do I know if the coil has a built in resistor.:rolleyes:
  2. lockwoodkustoms
    lockwoodkustoms
    Bob Drake sells them as well as Speedway motors
  3. tierod
    tierod
    Contact GMC BUBBA he is the Dizzy Master....
  4. Hoop-in-JAX
    Hoop-in-JAX
    "What caused the spring *** to melt. I do not see a ballast resistor anywhere nor do I know if the coil has a built in resistor."
    Probably running 12V, too. That'll definitely melt your ***s off.
    You need 3-4 amps ... via a proper resistor. Use your ohm meter to measure the resistance across the +/- terminals of the coil. Divide that into the volts you're running. Add whatever resistor is needed to drop down to 3-4.
  5. Redbows35panel
    Redbows35panel
    Sent it off to Bubba yesterday. Lookin forward to it's return, to see if all the praise is for real.:)
