Technical FLAME THROWER FAIL
Discussion in 'The Hokey Ass Message Board' started by Clik, Dec 7, 2021.
  1. Clik
    Clik
    So, I was playing around with a gas BBQ grill ignitor coil.
    It runs on a AA battery.
    I found that it would fire two standard spark plugs.
    I didn't want to do the wash-out-the-rings-ignition-interrupter-thing for something as trivial as flame throwers.
    I tapped a spark plug into the top of each 4" pipe.
    I made a couple of injectors out of 3/16" brake line.
    I hooked up an electric click-clack fuel pump to feed the injectors from a 1 gallon can so that I could mix various fuels.
    Fuel and spark were controlled with momentary switches.
    Test: FAIL. No flames.
    I then moved the plugs to the very bottom.
    So, I'm thinking that the spark isn't hot enough.
    I'm wondering if I could use a fast turn signal flasher to trigger regular automotive coils?
    Spoggie likes this.
  2. MCjim
    MCjim
    from soCal
    I can not help you with that, but I could sell you some firecrackers...
    samurai mike, SS327, Dino 64 and 6 others like this.
  3. 19Fordy
    19Fordy
    You are asking for trouble. STOP while you're ahead.
    Clik, Before you continue playing with fire visit the local burn unit of your hospital.
  4. Clik
    Clik
    Maybe you should sell that old Ford and get a modern safety car with funny bumpers, crush zones, side curtain air bags and shoulder harnesses.
    desotot, iwanaflattie, TA DAD and 7 others like this.
  5. alchemy
    alchemy
    I'm with 19Fordy, sounds kinda dumb and really dangerous.
  6. The idea sounds like a feasible progression in the experiment. I can't offer much more, apologies. Good to see you on the board mate, christmas blessings to you from down under.
    Clik likes this.
  7. I have toyed with a very similar idea. On the surface it sounds great, but I never went on from my mind and on to a real project. While I'm not afraid of fire, I do have a great deal of respect for both fire, and the pent up power stored in gasoline and other hydrocarbon fuels.
    Flamethrowers are cool and I will continue to be a spectator. Good luck with your project, just be careful.
  8. PotvinV8
    PotvinV8
    HEI distributor mated to a motor to get things spinning, wired to one switch. A spark plug in each pipe or two if you're feeling frisky.
    '80s VW mechanical fuel injectors mated to an electric fuel pump, wired to another switch. Small tank in trunk mated to said fuel system.
    Rev it up and go, ask me how I know. The results will probably scare you enough to remove the entire kit and kaboodle, but it will impress your friends until you burn your car down.
  9. Clydesdale
    Clydesdale
    my 2c,
    you need to vapourize the fuel for it to work, hosing it out of a 3/16 pipe isnt gunna cut it.
    That said, I probably wouldn't bother, it smacks of mid-intersection donuts sideshow BS.
  10. twenty8
    twenty8
    Might see you on the news.....................:confused::confused::confused:
  11. Roupe
    Roupe
    Baron, SS327, Clik and 1 other person like this.
  12. G-son
    G-son
    from Sweden
    So, you are injecting fuel into the exhaust, full of exhausts that don't contain any oxygen so the fuel can't burn, and try to ignite it?
  13. Greg Rogers
    Greg Rogers
    nnnnnNNNNOOO....
    Dino 64, Greenblade, Spooky and 2 others like this.
  14. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    2 main issues,
    1. You don't have enough spark,
    2.The fuel has to be vaporized to work.
    The fuel must be injected upstream of the ignition source... About a foot minimum should be close to enough to get the vapor to expand in the exhaust stream to get ignition.
    BUT I didn't tell you this... and I was never here.
  15. How’s about you don’t use LIQUID FUEL !!!!!! That may or may not ignite .
    Cause now you’ll have a puddle of fuel in your tail pipe , on the ground around your car, so when it dies ignite ……… it won’t be a happy moment.
    You need an ignition coil to get the HOT spark you need and a controlled way to fire the plugs multiple times in very short order ( milliseconds)
    and a way to inject the gas , not liquid fuel but a gas ( propane , butane etc)
    Flame throwers are cool …… I guess . But need to be. Done correctly to avoid a big mess
  16. 210superair
    210superair
    from Michigan
    Because that's the same! Lmfao.
    Personally I think flame throwers are gaf, but you go boyeeeeeeee.
  17. Clik
    Clik
    That's a possibility. I figured with two 4" pipes there'd be enough air near the outlets.
  18. hotrodjack33
    hotrodjack33
    I dunno...building a flamethrower system using un-burnt fuel/exhaust, and your choke is traditional!
    Building a flamethrower system using an auxiliary fuel system and injectors (besides being stupid), is more of a 1990s thing...and probably not really a HAMB friendly subject. IMHO
  19. Clik
    Clik
    You're really splitting hairs with the "traditional" thing. Every part used was available back in the day and it's not like I'm playing with a programable ignition system. Granted, flame throwers weren't traditional with some categories of hot rodders but they were with a lot of custom owners.
  20. Fortunateson
    Fortunateson
    They look cool (hot?) bit I’d never run one due to safety and/or liability issues.
    However a few years back I saw a news item on TV where there were apparently popular in South Africa where they exited not at the rear but just under the driver’s door. Use to prevent car jacking...
    alanp561, lothiandon1940 and loudbang like this.
  21. Mr48chev
    You east coast boys are really hung up on that flame thrower bs it seems. Far more than guys out west anyhow.
    Still I have to go along with the concept of the fuel being properly atomized and proper fuel/air mixture at ignition. Plus you most likely need to do some research on where to place the plug in the pipe. It seems that most of the clowns you see with flame throwers have the plug about half way down the pipe that serves as the tip.
    gimpyshotrods likes this.
  22. saltflats
    saltflats
    from Missouri
    Though it was rev it up, kill the ignition, pump the gas, then retard the ignition and hit the switch.
    Any others were with propane.
    jimmy six likes this.
  23. twenty8
    twenty8
    This^^^
    Stoichiometric ratio will be the secret..............you need oxygen.:rolleyes::rolleyes::rolleyes:
    Just remember, your skin is your friend......... When things go bang it happens real quick.
  24. Harv
    Harv
    from Sydney
    Yep.
    Normal gasoline engine exhaust has ******-all oxygen in it. Combustion in the cylinder eats almost all of it up. With a "traditional" flamethrower, you cut the ignition for a period of time. That lets the air flow into the cylinder, not ignite, and p*** into the exhaust. The plug can then ignite it near the exhaust tip. The oxygen needed for ignition comes from the cylinder, not the exhaust tip mixing.
    Igniting it further forward, near the muffler, is not a wise move.... very confined, and more likely to bang than flame. Almost every kid at some stage has tried coasting along, turning off the ignition (to fill the exhaust with air and fuel) then turning the key back on. The burning exhaust gas ignites the exhaust system in front of the muffler, and often detonates in the muffler. Most fathers have had to replace a bellowed muffler from their kids learning this :oops::rolleyes:. The Aussie term for such an activity is "key bangers".
    Cheers,
    Harv
  25. 52HardTop
    52HardTop
    I'm curious what Hagerty or Grundy, just to name a couple, would say about this?
  26. G-son
    G-son
    from Sweden
    Laugh, shake their heads and walk away?
    49ratfink likes this.
  27. lothiandon1940
    lothiandon1940
    ...........More likely, smirk, rip your policy in half and then walk away!:eek:
  28. Callmaker
    Callmaker
    This is my opinion on flamethrowers, and I know you didn't ask for it. You may not give a rats *** about your safety, but think about those who are around the damn thing when you fire it up. Stupid ****!!
  29. It's called natural selection.
