gidday, trying to use Shortbus's guide to making flame throwers for a single exshaust, got a few questions though where does the push*****on switch go? the guide mentions a push*****on switch, but only shows the ignition hookup in the diagram??? also it mentions a "coil" like the type that goes onto the dizzy? then the plug runs directly off that? and it says you need " Two Transistor Mounting Hardware Kits for TO-3 style case (#276-1371)." anyone happen to know what that consists of? as i wasnt able to find one of those? or could i just bolt it to the chasis? sorry about all the questions but im keen as hell to get it all hooked up incase you havent seen the guide its here - http://www.ennisenterprises.net/so-cheap/flames/ cheers,
Overdose, We would love to help you but it is proper here to introduce yourself.You will get more than flames in your tailpipe, You'll get them up your fart pipe.
Expect a bunch of lame slams to come your way for not posting an "intro" , There are a few people here who dont seem to have much else to do besides give new people a*****load of trouble for not knowing the " rules " before they try to get some info . Personally I dont give a***** about an intro . if you are into cool***** ( stuff I like ) and hang around long enough , we will all get to know you just fine as long as you arent a total**** . . . however , I'm sure that someone will try to help you out with what you are doing . I used a few of those kits in the magazines before to get fire , but they were pretty straightforward . I dont know about the one you are trying to use , but good luck .
