Flange to flange...
Discussion in 'The Hokey Ass Message Board' started by Ham, Jul 3, 2005.
  1. Ham
    Ham
    or backing plate to backing plate? Are these the same or different measurements? Anyone help me out...thanks.
  2. no , not to me...when i measure a rear end i measure the disstance from wheel mounting flange to wheel mounting flange...that is the most important
    from backing plate to backing plate is easy to measure beacuse you can do it with the wheels on and the rear in a car , but it means nothing to me
    i sometimes see measurements of housing flange to flange , but that is useless too , unless you have the measurements of the wheel mounting flange to the housing flange
  3. RonC
    RonC
    from Montebello
    Flange to flange usually referrs to the outside measurement where the wheels bolts up. Backing plate to backing plate is the inside measurement between backing plates.
  4. alittle1
    alittle1
    The flange is what the backing plate bolts to. The difference in the measurement could be the thickness of the flange.
  5. alittle1
    alittle1
    Must be an echo in here.
  6. Ham
    Ham
    Thanks guys, that helped to clear up some confusion...now, does anyone have a spare 8" or 9" they want to get rid of?:)
  7. Deuce Roadster
    Deuce Roadster
    Wheel mounting flange to wheel mounting flange is MORE accurate...IMHO.
    The difference in brake drums can throw the backing plate to backing plate measurements off.....
    http://www.dfwmotorsport.com/Fairlane/9inchrearends.htm
    Here is a site with widths listed.......for common Ford rear ends.....
