Technical Flat 226 with 3 speed OD question...
Discussion in 'The Hokey Ass Message Board' started by sillyasianz, Mar 28, 2014.
  1. sillyasianz
    sillyasianz
    Planning to swap out my stock 3 speed with a 3 speed OD from another 1950 shoebox ford. It's coming off a 8ba instead. Any idea if it's a direct swap or will I run into issues? I just plan to do a toggle switch for the OD. The 3 speed OD comes with Bell housing, fork, and throw out bearing. Will that bell housing work? What issues will I have?
    Doing this cause my stock 3 speed crapped out and ain't worth rebuilding. Just gonna put it away in the garage. This 3 speed OD is at a good price and off a running car.
    This is a temp fix until my c4 on the column setup is ready.
    Thanks!
  2. V8 Bob
    V8 Bob
    The '49-'50 6 & 8 transmissions are the same, but the '49-'51 6 & 8 cylinder bell housings are not, although they look very similar. The starter plates are totally different!
    Just swap transmissions and you'll be fin
    e. :)
  3. Should be a bolt-in using the 6 cylinder bellhousing. Be sure and use a relay on your toggle switch setup for the OD. The solenoid pulls some pretty good amps.
  4. Rusty O'Toole
    Rusty O'Toole
    Flat HEAD, flat HEAD. Why do people never make this mistake with a V8 Ford?
