Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. roseville carl
    roseville carl
    Well today had to put H20 pump in OT Tahoe but yesterday did get heads clayed and off to be trimmed a little....... I like using plumbers putty for the claying process as it sticks real good to parts and doesn't slide around on you.
  2. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Can't wait to see the finnished product! Keep goin' Carl!:)
  3. Model A Mark
    Model A Mark
    from dallas
    hey carl, mind if i ask, what kinda clearances did you have when you clayed ? and what are you expecting when you get the heads back ?
    and what do you set your valve lash to ?
    thanks.
    i love your build, it ort to be a fun engine to drive.
  4. Carl, that plumbers putty is a GREAT idea! Beats buying a ton of modeling clay that you lose after use!
  5. roseville carl
    roseville carl
    Mike get ready to go for a ride in May at Eagle!!
    Mark.. had .120 on one head and .090 on the other so gonna take some off and shoot for arounf 9.2 CR when I am done.I still have to do some internal work on the heads but that is for another story.........
    The valves are .011 and .013
    Trent yea I like using the putty works better than other stuff I have done and this way the grand kids can keep their playdough............
  6. Maybe take .010" off one and .040" off the other?
  7. roseville carl
    roseville carl
    something like that.........
  8. We'll talk. I'll even take pix of the process to post here.
  9. Model A Mark
    Model A Mark
    from dallas
    thanks Carl,
    so are you gonna shoot for around .040 piston to head clearance ?
  10. roseville carl
    roseville carl
    somewhere around that...........
  11. They are here!
  12. Toymaker
    Toymaker
    from Fresno,CA
    Looking good Carl!
  13. Hey Carl: Looking good so far - you're getting close. Would be nice to get to about .040 over the pistons with .060 to .080 over the valves at full lift. The turbulence caused by the tight piston squish has always seemed to be an important part of flathead horsepower. Are you starting out with a blower on this or NA? If it was NA, then having some higher compression definitely won't hurt yah.
    Keep cranking along! Looking forward to hearing it bark a bit! :rolleyes:
  14. Cylinder9
    Cylinder9
    Looking great so far. Can't wait to see it all together.
  15. roseville carl
    roseville carl
    Thanks Tim!
    Thanks Roc!
    CYL9 "Can't wait to see it all together." either can I, gettin excited now!!
    B&S: these heads are for the NA version, I have a set of hogged out 87CC 8BA heads for the 4-71 for future use if need be??????
  16. OK! Heads are milled as to Carl's request. I took .020" off one and .050" off the other, both are .250" from the surface to the top of the dome. I'm with Dale on the quench area, I like to see right at .040" (in my Y-Blocks of course) I know Carl will have a bit more than this but in the future if he likes we can take more off. It's a lot harder to put it back on. Pix will post tonight as the computer at the shop wint take my camera card.
  17. roseville carl
    roseville carl
    Thanx Tim .............
  18. Here's the heads before re-surfacing, they have quite a step to them and a depth of .300" and .270" from the surface to the top of the dome. Carl told me that the top of the dome on the piston is .210 above the deck. That is quite a lot of space between the two and we haven't factored in a gasket yet.
    Since my earlier post I have talked with Carl and he decided he wanted another .020" taken off, this will give him .230" depth on both heads. Wth a head gasket that is compressed to .030" - .040" that will give a more desirable quench area.
  19. roseville carl
    roseville carl
    Don't let out any secrets Tim!!!!
    Damn that looks a lot better after the cut gonna have to get into the garage and get the engine into the dragster!!!......Back to work fatso, ouch that hurts! Need to shave a few lbs offn the ol body for next years races I guess.............
  20. grovedawg
    grovedawg
    from Heber, UT
    I need to build a flathead. You guys are having WAY TOO much fun... Nice work Tim!
  21. fenderless
    fenderless
    from Norway
    Looking gooood Carl:)
    Seems like Flathead Fed's are popping up even several over here:)
    Builds like yours are an inspiration to us all! Thanks:)
    Br
    Kjell
    Taildragger&fenderless
  22. 38FLATTIE
    38FLATTIE
    from Colorado
    It's gonna be fun, Carl.......:cool:
  23. Heads and a crank are headed your way Carl!
  24. roseville carl
    roseville carl
    Thanx Tim, looking forward to it!!!!!!!!!!
  25. lippy
    lippy
    from Ks
    Lookin good guys. stay after it Carl!! Lippy
  26. roseville carl
    roseville carl
    We plan on it Lippy, by the way that is the coolest avitar I think I have ever seen!!!!!!!!!!!!!!!!!!!!!!!
  27. roseville carl
    roseville carl
  28. Crazy read the other post as well. I would try a sacrificial anode and see what happens.
  29. D_Lazaris
    D_Lazaris
    from So. Cal
    Woah... thats crazy... never seen anything like that.. Huh.
    Edit:
    Are your heads like this as well?
