Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. Kenneth S
    Kenneth S
    Nothing really, put this one on it then you have really done it!
    :eek: :D
  2. Toymaker
    Toymaker
    from Fresno,CA
  3. oj
    oj
    Now we're talkin. This is shaping right up, FED; 59a flattie; blower; killer zoomies..now about that distr, a gm hei will give it gender confusion!
  4. ChevyRat
    ChevyRat
    Looking great
  5. roseville carl
    roseville carl
    Got back from Arizona and finally got the coupling half I was missing, got the engine in and am starting on a new mounting for the Vertex Mag I picked up, have to make new lower unit for it, also re doing the steering idler as it was in the way of my zoomies and I didn't like the original attachment. Happiness is a five gallon bucket of shavings..... Anyway we're off to the races maybe.............The HEI is one I did about ten years ago for another flat project one of many around here......
    [​IMG][​IMG]
    [​IMG][​IMG]
    Scotty's Garage! likes this.
  6. roseville carl
    roseville carl
    Scotty's Garage! and Toms Dogs like this.
  7. 4tl8ford
    4tl8ford
    from Erie, Pa
    Carl
    Ya got the Race Face down pat - That machine is gonna be fun to run or for us less fortunate - to watch.
  8. You're a madman, Carl! I love front-engine dragsters, and a flathead, even better! If one of the moderators could put the pictures in a vertical format to make it easier for us laptop users, that would be great.
  9. Pete1
    Pete1
    from Wa.
    I'm not trying to be a smart*** but, why the transmission??
    We just used a multidisc clutch in the olden dayz.
  10. roseville carl
    roseville carl
    Course in the olden days I could rebuild this flattie for 250 bucks out the door but no more...
    Auto trans because I,m gettin older now, and easier is it for me, thats why no hand brake, it may not be the fastest but you won,t be able to wipe the grin offn my face...........thanks to Rocky for gettin the juices going again......
  11. Pete1
    Pete1
    from Wa.
    Roger on all of that..
  12. BigMikeC
    BigMikeC
    I can tell you from experience, that it takes quite a while to get the grin off your face after a p***!
  13. roseville carl
    roseville carl
    Added coupling guard, finished adapter for ign, welded up zoomies, fabbed rear trans mount, been busy..........
  14. lippy
    lippy
    from Ks
    Great job Carl. Your fabricating skills are top notch! I don't know you and please don't take this wrong, but that rearend housing mount is bothering me. Please put a plate over the top of the housing on the ends with some sleeves in the upright behind the housing like you did in the rails. Just bolt it to the front mount bolts you have and bolt it in the same way behind the housing and weld the plate to the housing. Please don't take this wrong. Just encapsulate the housing.BTW, you are dead on with the coupler, no u-joint, perfect. Lippy.
    scullandcrossspaners likes this.
  15. roseville carl
    roseville carl
    Lippy I wasn't happy with the original rear mount as the 5/8 bolts only went through a piece of small dia tubing that's why I made a large sleeve to run the top bolt through, the rear mount is also attached with another 5/8 bolt and a 1/2 bolt through a 1/4 plate attached to both the upper rail and the lower rail and added gussets to the rear end I don't think it will be a problem with the flattie power but I may revisit this, thanks.........Carl
  16. roseville carl
    roseville carl
    Got the most important pedal in today
    then it was time to try to make er stop
    one gusset here one gusset there.......
    Soo much to do so little time..............
    K.L likes this.
  17. voxnut
    voxnut
    from sacramento
    Very cool Carl!
  18. HemiRambler
    HemiRambler
    I'm with Lippy on this. Also no offense intended and if you say the word I'll shut up and not bother you again, but until then... why not make the rear end mount the same as they do on the modern cars? Meaning a plate welded to an upright and a matching plate welded to the axle and then bolted to one another.
    Also IMHO you're gonna want an anti rotation device on the axle as well.
    Am I missing soemthing or are you not planning on having a motor plate at the rear of the block?
    Nice car - it's gonna look super!
  19. roseville carl
    roseville carl
    Hemi, thats the way the rear end is mounted, a 1/4 plate welded to the axle and a 1/4 plate welded to the frame and uprights with two 5/8 bolts and a 1/2 bolt to secure them, there was no gussets originally, I added those for extra support........
  20. 51 Hemi J
    51 Hemi J
    Mike, you have any concerns about your head being above the roll bar?
  21. HemiRambler
    HemiRambler
    Roseville Carl, Maybe I am confused a little, but here's some pictures of what I was trying to say. The mounting plates on my ch***is (actually 2 per side so the bolts are in double shear) are welded from top to bottom spanning the full distance and are welded to 3 rails. The bracket on the housing is also welded a full 360 degrees around the housing. In addition there's the anti rotation device mounted to the front of the pumpkin. The rules state that has to be attached to the frame with at least (3) 3/8" bolts - so naturally I used 4 - a little overkill never hurts. My coupler cover bolts to the front bearing support - nothing wrong with yours just showing mine - matter of fact I like the fact that yours splits to inspect - mine slides forward. IIRC the mounting bolts for the rear axle are 1/2" (maybe 7/16 - I forget) but these are also spec'd out of the rule book. In my case I was too cheap to use the NAS bolts and instead used LONGER than "normal" bolts so that the FULL SHANK goes thru all 3 plates and then I machined off the extra length so they were just enough for the nuts to go on. I also show the adjustable trans mount. Once everything is loaded I can still tweak the trans up/down left right so that the coupler "rattles" meaning it is perfectly aligned. Just some food for thought - I'm no expert just a fairly well read amateaur.
  22. roseville carl
    roseville carl
    Hemi thanks for the pics they save a thousand words, I might have to revisit the rear end, that's a nice setup you have there............ Carl
  23. roseville carl
    roseville carl
    well bent some copper and need to get some H2O into the picture
  24. BigMikeC
    BigMikeC
    Yes, but it didn't seem to bother them back in the day.
  25. roseville carl
    roseville carl
    Got started on the roll bar modifications this week[​IMG][​IMG][​IMG]
    [​IMG][​IMG]
  26. fxfxr
    fxfxr
    from eureka, ca
    This is great to watch. Mad skills on fabrication. Congratulation on project so far.
  27. Toymaker
    Toymaker
    from Fresno,CA
    Lookin' good Carl, maybe when your done you can come help me :D
  28. roseville carl
    roseville carl
    Yea Rocky the worst part is for every 3hrs working I have to spend 1 hr cleaning up so's I can find all the **** I left laying around.......
    Part Timer likes this.
  29. roseville carl
    roseville carl
    Roll bar mock up ready to tack together and weld up maybe........
  30. Skotz
    Skotz
    Wow, Carl.....I just found your thread....Love the Flathead FED build:D. I am in the process of a "Very Similar build".....I'll post a shot of it as of last weekend.(wish I could figure out how to post large pictures as you do, but as of now, haven't been able to figure out the "simple" instructions that I have read:rolleyes:).
    We have come up with some very similar solutions on our Dragsters... "great minds must think alike"....haha
    I'm gonna post some shots after the Roundup this weekend, and I didn't want to "dilute" your thread....Great Thread.
