Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. roseville carl
    roseville carl
    Tim, Dale, they are on the way..................
  2. skovbamsen
    skovbamsen
    Greate tread... And i Nice build..
    Here i Denmark old machine guys used to putt at pieces zinksheet in the water jackets All along the length of the engine..
    Galvanic corosion will over time eat new sleves aswell..
  3. roseville carl
    roseville carl
    skovbamsen: Thanks
    Well another day and spent the last two days making the front pulley extension for the fuel pump. You start with a chunk of aluminum and remove everything that does not look like it belongs there, spend time cussin and cutting fingers because you ain't the swiftest in the world......but in the end you end up with this.....
    the start.....
    <TABLE style="BORDER-TOP-WIDTH: 0px" cl***=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR><TD cl***=thead colSpan=2>01-03-2012 04:57 AM</TD></TR><TR ***le="Post 7303633" vAlign=top><TD cl***=alt2 width=125 align=middle>skovbamsen</TD></TR></TBODY></TABLE>
    Stage 2
    Stage 3
    and you end up with this.....
    Only cost was a little alumionum and some skin offn a finger, go figure....
  4. ^The story of my life^
  5. Carl you amaze me! Great machinist and good lookin' too.
  6. roseville carl
    roseville carl
    Thanks Tim but just an ol fart too cheap to buy stuff, and I gotta keep Johnsons' and Johnsons in business making band-aids
  7. Vergil
    Vergil
    Always a pleasure to see your skills Carl, I sometimes can't make it to bandaids and have to go with black tape to keep things moving but at least what you end up with is awesome and I might have to toss what I was working on to the oops bin.
  8. Just dont leave the chuck in the lathe when you flip the switch!
  9. I'm sure you mean the "T" handle, I remember training films in HS where the showed the consequences of this. :eek:
    I always use plain masking tape, it's handy and seems to stick the best. :rolleyes:
  10. roseville carl
    roseville carl
    Memo to self....
    Keep finger out of spinning end mill....
    Oh it ain't too bad with these small lathes but leave the T handle in my old 14X40 7 1/2 Horse Hendy and then you had a real problem and you never wanted to make any mistake with that thing it would eat you alive.......
  11. fenderless
    fenderless
    from Norway
    Be careful Carl! You need those finger and hands to pilot the dragster:D!
    I love seeing all those small things you make! Great work:)!
    Br
    Kjell
    Taildragger&fenderless
  12. lippy
    lippy
    from Ks
    Great job Carl! You are an inspiration to all us do it yourselfers. :) Lippy
  13. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Aw, "t"'s in the chucks in the lathes in HS..... Saw a bunch fly and the teacher VERY pissed off. = flying shrapnel!
    Carl- That came out awesome! Very Nice! Is it half,or should I say slow down 50%? Either way,Good Job Bud!
  14. roseville carl
    roseville carl
    Ah Mike I went from a 1.08 to a 1.21 ratio so I gained about 10% maybe, but now I can use a 5 rib belt and mount the fuel pump down lower and have less rotating m***. .....
  15. Hey Carl - looks like you have it covered for the fuel pump drive!
    When I first saw the picture, thought you were making a blower drive on the end of the fan mount -- glad it is just a fuel pump drive! :rolleyes: I've seen guys try to use those crank pulleys for blower drives - not a good idea.
    Keep cranking - and keep your body parts out of the mill will yah! :D
  16. roseville carl
    roseville carl
    Na Dale when I put the huffer on it will be on a Fluid Dampner with drive on front of that, not the stock pulley..............
  17. roseville carl
    roseville carl
    Well spent some time thinking about the crankcase scavenging and made some changes to pan in preparation for same. 1/2 NPT for an 10AN fitting to a vacuum pump...............
  18. Good idea! You may want to also pull from the valley area - where the fuel pump originally went. Heck, while you're at it - maybe make some teflon crank s****ers! :D
  19. dragsled
    dragsled
    from Panama IA
    hi Carl what is this your doing ? a crank case vac system , or puke tank so to speak thanks Tim Jones
  20. roseville carl
    roseville carl
    Eventually I will put a vacuum on the crankcase and this will be my attachment point, I will need to seal the dipstick and all other points of leakage. I will turn the front seal 180 so the vacuum will **** it shut, the outlet from the vac pump will go to a puke tank.............
    Yea Dale been thinking about a s****er also now that my rpm figures have increased........
  21. What's going on with the engine? Hope it's ready to run soon.
  22. roseville carl
    roseville carl
    still lookin for a few parts...... oil pump pickup(on order), Oberg oil filter, still lookin for one, vacuum pump, some small stuff but looks like a couple of weeks left, then off to the races I hope..........
  23. Let me know when you head to Sac. Speedway I'll haul Elwood up there and join you. ;)
  24. roseville carl
    roseville carl
    sounds good to me
    We hope to be at Speedworld in Ariz on the 3rd-4th of March also....
  25. roseville carl
    roseville carl
    Well back home and had to clearance the oil pump idler case for the bolts in converter.........
    However just to show that not everything goes smoothly......
    Now to weld it up and grind some more off..............La te da...
  26. dragsled
    dragsled
    from Panama IA
  27. roseville carl
    roseville carl
    Thanks Tim but already ordered one on egay 2 days ago............
  28. Sounds like you plan on some travelling this year Carl?
  29. roseville carl
    roseville carl
    Yea hope to do something before I'm too old to move, course some have said I'm already TFO....................
  30. 64 DODGE 440
    64 DODGE 440
    from so cal
    We're never to old Carl, those "young whippersnappers" are just jealous and afraid we'll beat them. Old age and treachery will beat youth and enthusiasm any day! ;)
