Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. roseville carl
    roseville carl
    Yea Tom I need all the help I can get at the other end, thats why the 4-71 is in the works
  2. 38FLATTIE
    38FLATTIE
    from Colorado
    Looks good Carl! Good luck this weekend!
  3. roseville carl
    roseville carl
    Thanks Buddy, yea its getting excited time about now!!!!
  4. D_Lazaris
    D_Lazaris
    from So. Cal
    Looks good! See you this weekend! A UFRA sticker would look good on that scoop! ;)
  5. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, how did the 'mailbox' scoop work?
  6. fenderless
    fenderless
    from Norway
    How did it go this weekend Carl. Tried to look at the livestream, bot was disconnected several times.
    Taildragger&fenderless
  7. roseville carl
    roseville carl
    Well Kjell we lost the trans last time out at test n tune, thought it was just a linkage problem but when we got down there friday we found out it was a little more terminal than that. But I did get to pit for the Antique doll and Rocky let me run the Evil Twin! Do have it apart and am in the process of making the trans bullet proof now.........
  8. Skotz
    Skotz
    4-71.....Flathead....."THE" way to make it "think" it's not a Flathead:rolleyes:
    Thanks for posting all your updates...."one of these days:rolleyes:", I'm gonna figure out how to "post pictures" the easy way....till then, I enjoy "your" progress shots
  9. Old6rodder
    Old6rodder
    from SoCal
    Carl, my curiosity's up. What turned out to be the actual problem?
  10. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, What ****** are you running? I have an extra Muncie-if memory serves me correct, it's a wide ratio m-21. I might even have a Vertigate shifter for it.
  11. roseville carl
    roseville carl
    Thankx Buddy but im running a C4.......
  12. fenderless
    fenderless
    from Norway
    Hope the ****** is not too damaged Carl!
    We are gona come back stronger next year:D!
    K
  13. roseville carl
    roseville carl
    nothing that can't be fixed with enough parts and labor.................:D:D
  14. Carl I use a 904. In reality it isnt a lot dfferent then a C4. I machine the reaction plate so it sits proud out of the retaining clip and also sneak a bit off the face of the apply piston. this gives me enuf to sneak in an extra clutch plate and steel. I do it in both the direct clutch and forward clutch. Ie if I have a 4 plate clutch stock and I add another clutch plate and steel i now have 25% more holding power and have not bothered the trans at all hydraulically. The other place i have had trouble is the most forward sealing ring on the stator support for the direct clutch drum.(when it starts to fail high gear goes away a bit and MPH drops a few MPH) I now run a teflon seal there as it was prone to failure at race RPM. I also run mobil one synthetic trans oil which ended wear completely in my race trans. The safe operating temp for Mobil one trans exceeds the melting point of aluminum so it was a no brainer when I realized that. You probably have all this anyway but just in case mention it.
    don
  15. roseville carl
    roseville carl
    Thankx for the info Don, I appriciate it.......
  16. Thanks for the tech info - you always bring something valuable to the table!
  17. Goose
    Goose
    Hey Carl,
    Here is a run from Brown County Dragway in Indiana about a month ago with of Flathead powered FED aka "The Rail Job". Our best run on the 1/8 mile so far has be 8.28 seconds and 83 mph. It has a old Ford Econoline 3 speed ******. We are looking for a top loader for it, but haven't found one yet. Here is the link!
    http://www.facebook.com/photo.php?v=371800586224188
  18. roseville carl
    roseville carl
    cool Goose, post some pics!!! then join the UFRA, start a chapter back there!!
  19. Goose
    Goose
    Here are a few pictures Carl. The rail belongs to Tom Culbertson here is Indianapolis. It has been kind of a Road Rocket Car Club project. I built the motor for it several years ago at the World Of Wheels here in Indianapolis. We took it out last winter and I went through and freshened it up and we put a new cam in it that we had Schneider grind for us. It is an old Scotty Finn Ch***is.
  20. dragsled
    dragsled
    from Panama IA
    Great lookin car Goose Tim Jones
  21. Goose
    Goose
    Very cool Tim!!
  22. roseville carl
    roseville carl
    thanks Goose, great lookin car
  23. roseville carl
    roseville carl
    Well got the trans apart and looks like too much lead foot for the clutches and bands, ordered new parts to make it bullet proof..........the beat goes on........
  24. What the hell Carl! You making all kinds of flathead power and now you're tearing up modern transmissions? Good for you! :rolleyes:
  25. roseville carl
    roseville carl
    Yea Dale the worst part is when I tear up **** up it takes time away from fabbing up the blower and other stuff I want to do, that tic's me off. But so is life in the slo lane. He he, at least I know that the new engine is performing so far, so all is not lost...........
  26. fenderless
    fenderless
    from Norway
    What monster Flathead have you buildt Carl? First killing the rear-end, now the transmition:eek::D? I know you have been in the game for a while, what's your secret?:D.
    Pluss adding more power....where is this gona end...:D?
    Kjell
  27. roseville carl
    roseville carl
    no secret Kjell, just doing stupid things so I can learn all over again........
  28. 38FLATTIE
    38FLATTIE
    from Colorado
    It'll be killer, when you get done!
  29. Goose
    Goose
    Sorry to hear about your ****** problems Carl! I will be out your way the end of November. My son lives in Placerville with his mom. I am coming out for his 6th birthday. I wish I would have some spare time while I am there, but will be busy with my son. I don't suppose there are any drag races going on in Sac on Dec 2nd? I do have to say I have been impressed by all I have read and seen. You are quite the machinist. Reminds me of my dad and all the things he used to dream up and build.
  30. roseville carl
    roseville carl
    Nothing going on except test n tune on sat track is closed for winter Placerville is about 1/2 hr from here if you have time...........
