Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. roseville carl
    roseville carl
    Methinks this ain't the first time you've resorted to this cobble, Sir ....... :D
    he says with a smile!!!
    No Ol 6 it just takes me longer now...........<!-- / message --><!-- sig -->
  2. fenderless
    fenderless
    from Norway
    It looks nice& tall:D!
    I have not taken my C4 appart, but hope it is as the previous owner stated, a race ******!!:)
    The only thing i know is that it's a manually shifted reversed and with a transbrake!
    Taildragger&fenderless
  3. 38FLATTIE
    38FLATTIE
    from Colorado
    Looks good Carl! I'll be home this coming weekend and get the blower parts to you!
    You need a tri-power setup on that bad boy!:D
  4. roseville carl
    roseville carl
    What I need is a Hilborn two port...........
    but maybe I can make my own.........
    thanx for the offer!!!........
  5. Toymaker
    Toymaker
    from Fresno,CA
    Love It, you may have to drive with mirrors tho :D
  6. roseville carl
    roseville carl
    maybe I can get my hands on a tank periscope???
  7. Carl, think Ford Ranger 3.0. I have an old throttle body off one that would work great matched up to another. It's yours if you want to 'spearmint.
  8. roseville carl
    roseville carl
    sounds good Trent might try it!!!
  9. roseville carl
    roseville carl
    Well got the front pump apart and **** its toast, so now need to find early c4 front pump..............
    Of course when you are a member of the Bumps n Bruises crew....... you almost cut your finger tip off getting bushing out of pump..........
    split it almost half way.......
    so what the hell is new......................
  10. dragsled
    dragsled
    from Panama IA
    Carl let me know if you can't find a pump, i have an C4 sitting here ,I'll pull the pump out and send it to you if you can't find one out your way, And watch those fingers, Tim Jones
  11. roseville carl
    roseville carl
    Thanks Tim but I just ordered one from a junkyard, my problem is I'm using an early case with a 24 sp input shaft so its tough to find..........
    probably my luck the guy at the yard picked the wrong one, ah, who knows..........will find out in a coupla days.......
    course my other trans in the ICT is a later C4 so I get the best of both worlds.......nothin can be easy
  12. dragsled
    dragsled
    from Panama IA
    I went out and counted my it's a 26 spline,
  13. roseville carl
    roseville carl
    Thanks anyway..........
  14. One Finger John
    One Finger John
    Shoot .... that's only a one band aid cut. No big deal. At our age one maybe two days tops to heal completely.
    Be careful, John
  15. roseville carl
    roseville carl
    John your name would fit our crew to a T, I've got three fingered Jack as my crew chief...........
  16. roseville carl
    roseville carl
    Well parts haven't arrived yet so there was nother problem to attend to, that is a jack to lift the ch***is in the pits to get my stand in place at the push bar, humm have an extra jack and some left over matl from a P/U rack............ well the concept works now to just do a little finish work on it........
  17. 64ONEOFF
    64ONEOFF
    from Md.
    I sat in a friends of mine that he is redoing at The Rodders Journal Show.... Those guys had balls of Steel. I could not imagine driving one of those cars....Your *** is hanging in the wind and your balls are one the quickchange.. I have much respect for the guys that raced them.
  18. roseville carl
    roseville carl
    Ah but what a thrill it is to light one up, most fun you can have with your clothes on!!!
    Even better when its the Evil Twin of Rocky's now that a blast!!!!!
    But like you say back in the day with a big Chrysler on juice with an old rear end it was tricky I guess..............
  19. 64 DODGE 440
    64 DODGE 440
    from so cal
    If it was easy, everyone would be doing it. :D
  20. roseville carl
    roseville carl
    This is to show everyone the difference worn out front pump, check out clearance on small gear to housing.......
    pump that is ok, housing not worn to ****.........
  21. Toymaker
    Toymaker
    from Fresno,CA
  22. roseville carl
    roseville carl
    Thanks Roc got back from the city today and my parts are in, damn now I get to put her together again!!!
  23. Hey Carl - as I know nothing about 'slush boxes' - are you talking about the space/gap between the outsides of the smaller gear and what looks to be a rounded piece of the housing itself? Enlighten the ignorant! :rolleyes:
  24. roseville carl
    roseville carl
    Yea Dale that space that looks like a half moon is where the oil gets pushed into the outlet side of the pump and squished like the case of a h20 pump and when the case gets worn you loose the squish to make pressure the case should be tight and a little bit of wear is ok but this is excessive allowing the pressure to leak out......kinda like your oil pump when the bottom plate wears out and allows oil to just circulate around the gears and not squeeze out the outlet
  25. 64 DODGE 440
    64 DODGE 440
    from so cal
    I always thought you just used heaver weight oil when that happened. :D
  26. roseville carl
    roseville carl
    Yea Tom, Castor oil or Moll***as
  27. And maybe some sawdust, banana peels or other such stuff . . . yeah, that's it!:eek:
    Thanks for the knowledge - as I have none!
  28. roseville carl
    roseville carl
    only on the ones we put up for sale............
  29. 64 DODGE 440
    64 DODGE 440
    from so cal
    Amazing how quiet straight STP will make a manual transmission.:D
  30. fenderless
    fenderless
    from Norway
    Thanks Carl:) I learn something every day:)!
    Kjell
