Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. roseville carl
    roseville carl
    Yea Kjell it seems stupid to me also on a car will never see the plus side of 130 but I do understand to replace them after an accident where they have been stressed, hard stressing them in the garage or at the strip. But I guess we have to keep the seat belt people in business, at least its made in USA.
    Yea Buddy every 2 years but it is just as much to recert them as to get new ones...........
  2. dragsled
    dragsled
    from Panama IA
    I feel the same way Carl, The safety bizz is a money maker with all the recert deals the sanctioning bodies make the racers do, Car looks great as always good to see it back together,,, Tim Jones
  3. roseville carl
    roseville carl
    Well got the new jack finished and it works......
    Got the trans done and fired her up..... no leaks and looks like everything is ok once again time for T&T and off to the drags................
    Also got this magnetic sign to add to the mix/ art work by Lance Hampton at artboink.com
  4. dragsled
    dragsled
    from Panama IA
    Well I see Roseville Archimedes:D is still at it ( Give me some s**** iron and I will lift this Dragster):confused: Nice jack and sign Carl,,,, Tim Jones
  5. Sanford Graham
    Sanford Graham
    I have come to the conclusion I like in the wrong place :( What great stuff you have and do........sandy
  6. roseville carl
    roseville carl
    Just trying to use my head for something besides a hat rack Sanford
    Yea Tim I got tired of trying to lift the digger with a sissors jack and wanted something besides a floor jack now that I have gone to smaller tires the floor jack won't fit under the frame so's its make something that will work........
  7. roseville carl
    roseville carl
    Well she is back together now and wa la, now I have all three gears and Reverse, course it was not without trials and tribulations.......... sometimes its the ****s getting older............
    Now on to Eagle Field on the 16th!!!!.......... or if its rained out a T&T at Sacto on sat............
  8. dragsled
    dragsled
    from Panama IA
  9. roseville carl
    roseville carl
  10. 9sectruck
    9sectruck
    Cool video Carl, thank you for posting it.........you guys seem to be having way too much fun, Eagle Field looks like a great place to run.
    Quick question for you, how long do you think you can safely run the motor with no water in the block?
    Have just finished by build and am nervous about running it for too long.
    BTW it's not a flathead it's a SBC motor.
    Thanks
    Ray
  11. roseville carl
    roseville carl
    I usually run it about 30-60 seconds total gets to about 190 then put a set of fans on her to cool her down takes about twenty minutes to get below 100 then its off again, I try to start after my opposition then get into the lights quickly......... next will be alcohol then I won't have to care about the time I run it.........
  12. Thanks for sharing Carl!
  13. roseville carl
    roseville carl
    Thankx Trent
    And yes Ray, Eagle is a total blast, no big timers and just run for the sake of it, what else is there!! Rocky has a special place reserved for him for thaking all the time and effort to do this, he should be commended!! ..............
  14. Old6rodder
    Old6rodder
    from SoCal
    He should be Cannonized ...... but don't tell HIM that. :D
    Yep, GREAT video. :cool:
  15. 9sectruck
    9sectruck
    Thanks for the reply, so you run a temperature gauge then, didn't think one would work if the sender unit wasn't emersed in water..doh:eek:
    So it just sends a reading to the gauge of heat whatever the heat source, have to try that out, will save a lot of guessing.
    Wheres my wifes hairdrier........:D
    Ray
  16. dragsled
    dragsled
    from Panama IA
    Cool Video Carl, Tim Jones
  17. roseville carl
    roseville carl
    Yea Ray when I filled my block and heads I used a release agent on the sender so that the fill material would be up against the sender probe works great on a flathead ............
  18. dreracecar
    dreracecar
    from so-cal
    The belt issue---
    As a former Tech I have seen belts with welder burns, oil soaked, dryed out and faded to a point you could not tell they were originaly black, and some that had the holdown bolt thru the webing. It is for racer that the webbing must be changed often. The sun beating down on it unshaded in the pits, waiting in stageing, getting caught in a rain shower affects the webing. But as a tech inspector I can only judge mounting and any visable damage and Manf. date. I am not allowed to or able to ***es the webing itself an only have the Manf date to go by. If not, and there was tragity the finger of blame goes to me because I thought the belt webbing looked good to me. WE cannot rely on EVERY racer to maintain there safety equiptment to the best standards possible, so for that reason EVERYBODY must get there Equipment-Repaired, re-certed, or replaced.
  19. roseville carl
    roseville carl
    I can understand that...............<!-- / message -->
  20. Sanford Graham
    Sanford Graham
    They are Big, but work great. Have you been too Bubba's in Indy? nice shop, nice shop and area for sure. Bubba is very knowledgable and helpfull.... sandy
  21. roseville carl
    roseville carl
    Well had to do a little TLC on the ICT and grandson got a chance to help the ol man....................
    This was a little different since "last time"....10 years ago...
  22. dragsled
    dragsled
    from Panama IA
    Cool Pics Carl , BTW What did you have to do to it, Tim Jones
  23. roseville carl
    roseville carl
    uh lost a rod bearing Tim..........
  24. roseville carl
    roseville carl
    Well took er out to TnT saturday and the ****** works great finally now its off to Eagle in May....ho raay......
  25. roseville carl
    roseville carl
    Well finally got a pour that will work.........
    All in all a good saturday in Roseville...................
  26. dragsled
    dragsled
    from Panama IA
    Looks good Carl, Did you change the sand mix to have it come out, or do something else? Good talking to you the other day,,, Tim Jones
  27. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, that looks great!
  28. roseville carl
    roseville carl
    Tim did not change the sand mix but put the pocket in the bottom so there was less metal and added a second riser not perfect yet but it will work, now to make a second one in case of damage........
    Thanks Buddy I will bring the bracket back to you when you Dyno..... soon I hope?
  29. roseville carl
    roseville carl
    well got to test out the containment vessel the other day, blew out the bottom of mold.........
    and one piece looked wierd......
    memo to self, be glad you put mold on containment vessel........
  30. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, what are you teaching that grandson??:eek:
    LOL!
