Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, I only use my suit once or twice a year.
    As expensive as it is, SOMEONE should get some use out of it the rest of the year!;)
  2. roseville carl
    roseville carl
    Yea that does **** doesn't it Buddy, how long does the tag last for the suit??
  3. I aways wanted to play with ethonal but we only have two places to buy it here and niether is nearby.
    Don
  4. Saxon
    Saxon
    from MN
  5. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, I'm not sure. I'll check it out when I get home Thursday.
  6. dragsled
    dragsled
    from Panama IA
    Hi Guys I believe a 15 or a 20 Spec suit has to be recertified every 5 years Tim Jones
  7. Kenneth S
    Kenneth S
    It's every 5 years for sfi spec 3.2A/10, 3.2A/15, 3.2A/20 suits.
  8. 38FLATTIE
    38FLATTIE
    from Colorado
    Gotta few years left then-I ordered it new summer of 2011.
  9. fenderless
    fenderless
    from Norway
    Epic:) Would have been cool to have my Sidewinder over there:)
    Kjell
    Taildragger&fenderless
  10. roseville carl
    roseville carl
    this is what happened Friday night under the lights.....
    Made a mental note to myself... From now on try on the parts before going to the track to make sure everything fits... see third carb fuel line...
    Got back home and got this in the mail.....Thanks Dave Mc Cain!!
    Humm looks like without much trouble I just might have a two port....
    The leftover aluminum will be melted down for future flathead parts !!!
  11. 64 DODGE 440
    64 DODGE 440
    from so cal
    Not seeing the problem Carl, guess my old eyes are missing the details.
  12. greaser
    greaser
    Fuel line interference with the head gooseneck??
  13. dragsled
    dragsled
    from Panama IA
    Way to go Carl,, makin junk parts into gold,, Tim Jones
  14. roseville carl
    roseville carl
    thas it ........... had to do some modification at the track.......
    <!-- / message --><!-- sig -->
  15. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, that's gonna be a wicked cool setup!
  16. roseville carl
    roseville carl
    Sure hope so Buddy, now to cast the scoop build the adapters, get a barrell valve see if I can get enough pressure out of my old Hilborn Pump ect. ect. ect. so much work ........ shootin for 2014......
  17. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, I've got a pump that will work for you! Remind me to bring it to the dyno.
  18. roseville carl
    roseville carl
    Thanx Buddy I would appriciate that!!
  19. Hopefully a Hilborn 150 #0 . . . would be perfect!
  20. Gree5ndf
    Gree5ndf
    from usa
    That is going to be a BAD BAD ride![​IMG]
  21. 38FLATTIE
    38FLATTIE
    from Colorado
    Can't remember what the spare is-either a 0 or a 1/2. do you remember, Dale?
  22. roseville carl
    roseville carl
    Thanks Buddy for all your help on this project, got some more done today....
    Kinda like the way it looks up there now to cast a scoop, make a drive snout and end plate, rebuild the blower and other ***orted ****......
    Just pluggin along..........
  23. dragsled
    dragsled
    from Panama IA
    Looks like it was made for it Carl, You'll have to cast B&B Racing on the side of the scoop,, Tim Jones
  24. Carl, do you need that throttle body to try?
  25. roseville carl
    roseville carl
    Thanks Trent but I think I will go with this two port set up, kinda like the ol time looks of it.........did you get the turbo hooked up yet??
    yea Tim just what I was thinkin.........
  26. Duh, your setup already takes the place of that body/****erfly I have!?:eek:
  27. D_Lazaris
    D_Lazaris
    from So. Cal
    Here is that video, sorry it took so long. BUT ITS GREAT!
    <object width="853" height="480"><param name="movie" value="http://www.youtube.com/v/araguPr4UWk?version=3&amp;hl=en_US&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/araguPr4UWk?version=3&amp;hl=en_US&amp;rel=0" type="application/x-shockwave-flash" width="853" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
  28. roseville carl
    roseville carl
    Thanx D it looks even better than I thought, neat run thankx.......
  29. fenderless
    fenderless
    from Norway
    Your 2-port looks perfect Carl:) And when you cast the B&B scoop, why not cast a couple of B&B 2-ports;)
    The C&D video from Eagle Field is epic:)!
    K
  30. Hey Carl:
    Don't know if you're trying to cast your own scoop to exactly fit and have your own lingo on it, but another approach would be to buy a 2-port scoop from Hilborn and adapt it to yours. The centerlines of the holes will not be correct, but it would be a great place to start. Seems they are not cheap - about $250 or so.
    You'll like that setup when you are through!
    PS: I have a two-port . . . can take pictures of anything you like on it.
