Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. dragsled
    dragsled
    from Panama IA
    Looks nice Carl, Is that a rachet type deal, Tim Jones
  2. roseville carl
    roseville carl
    Tim, HF tie downs with wrench to tighten them thats separate gets stowed when not in use, I was tired of chain, bolts and nuts and a binder so decided to do this, simple and easy to tie down now...........
  3. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, I'm loving the blower and injection setup!
    I can't wait to see this in person!
  4. roseville carl
    roseville carl
    Well another side trip, this has been in the garage taking up space for about a year or more now so I finally got off my ***.......
    so a little effort and wa la a used oil storage container.....
  5. dragsled
    dragsled
    from Panama IA
    Nice Carl ,sure beats the 5 Gal buckets I use ,,,, Tim Jones
  6. carshopowner
    carshopowner
  7. roseville carl
    roseville carl
    Only about 10 times Glenn, thas one neat Flathead............
    yea Tim and the price was right a buddy of mine gave it to me, suure will beat the 5 gal buckets I have all over here, make a little more room for other **** in the garage........
  8. 64 DODGE 440
    64 DODGE 440
    from so cal
    Looks great, how much does it hold Carl?
  9. roseville carl
    roseville carl
    32 gallons Tom, lots of changes before emptying..........
  10. afaulk
    afaulk
    Carl that's sharp. A lot neater than my old oil drum LOL. Allan
  11. I agree! :rolleyes: or old Sunoco fuel cans. :p
  12. Old6rodder
    Old6rodder
    from SoCal
    Really solid tie-downs, no worries about strap abrasions. :cool:
  13. roseville carl
    roseville carl
    Hey its here Buddy anytime, now I think I can get back on the fabrication of the blower since the ICT is finished.........
    yea **** I really like this idea better than what I had before with chain around the frame.......
    <!-- / message --><!-- sig -->
  14. roseville carl
    roseville carl
    Well the more I do on this thing the better I like it!!!!
  15. Model A Mark
    Model A Mark
    from dallas
    That looks sooooo good, Im a little jealous of the injectors.
  16. 38FLATTIE
    38FLATTIE
    from Colorado
    Carl, Randy and I are getting started on a 4-71 FlatCad fed, with 4 carbs converted to injection.
    We're gonna have to race!:D
  17. roseville carl
    roseville carl
  18. dragsled
    dragsled
    from Panama IA
    Sounds bad ***!!!!:D
  19. dragsled
    dragsled
    from Panama IA
    Blower is gonna look great on your car Carl, Can't wait to see it all come together,, Tim jones
  20. roseville carl
    roseville carl
    either can I Tim, either can I
  21. I want to see this! Better get it out the Eagle Field when it's done.
  22. roseville carl
    roseville carl
  23. We just pour our oil on the weeds.
  24. roseville carl
    roseville carl
    but you don't live in the "enviormential tree huggin, frog lovin, salamander kissin" state of Calif either Trent. Its hell out here................ don't they realize that oil came from the ground, WTF...............
  25. Goose
    Goose
    Hey Carl,
    I was wondering if anything needs to be done to the ignition timing on the flathead when you install a blower? We have acquired a Roadrunner blower setup for the rail.
  26. metalman
    metalman
    Not that Carl wouldn't have good input but if you have a Roadrunner setup why don't you call Joe Abbin? He for sure can help you with your setup, he got a bit of experiance with those!
  27. roseville carl
    roseville carl
    I run a Roadrunner on the ICT, and you have to scale back the timing I use 20 deg max with 2 degree static all in by 2000, I also use a 6al box with blower retard installed and an old chev mallory dual point that I converted to electronic with a pertronix trigger, been running it for ten years now.
    see..... http://www.flatheadv8.org/hei.htm
    course thats for the street and for race applications you need to keep an eye on the plugs, with the mallory its easy to change the curve...........
    and the timing tag will let you know where you are.......
  28. Timing - blown application: It all depends on the fuel that you're running and the amount of boost. If you're running specialized race gas, then you typically use more timing.
    1) What boost are you planning . . . or maybe a better question is what boost does that thing make?
    2) Also - my guess is that you won't have an inter-cooler?
    Give us some more info and I can give you a good starting point.
    B&S
  29. Goose
    Goose
    From what I have read it has 6.6 lbs of boost. We run Cam 2 race gas which is about 105 octane. We also run a vertex magneto. No inter-cooler. The engine is about 295 ci.
  30. Goose
    Goose
    I was also wondering about the compression ratio on the heads. We have Edlebrock 400 heads. I am wondering if we have too much compression? From what I got off the roadrunner site it looks like we do.
