Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. roseville carl
    roseville carl
    Well Tim since ya asked just happen to have a few, seems that the bolts holding the pulley onto the engine pulley came loose so will replace this...
    with this.....
    due to this.....
    [​IMG] [​IMG]
    hell may even loose a few lbs in the process.....and free up a coupla hp
  2. fenderless
    fenderless
    from Norway
    Ups;) Why does Things like that happen, when we don't expect it to?;)
    Will the Electric pump be big enough when you put on the huffer?
    K
    Taildragger&fenderless
  3. roseville carl
    roseville carl
    No Kjell, but that's another story........
  4. roseville carl
    roseville carl
    well got rid of about 6lbs of weight and maybe saved a coupla hp by going elect......
    [​IMG] [​IMG]
  5. dragsled
    dragsled
    from Panama IA
    Looks good Carl have you had it running it yet,,, Tim Jones
  6. roseville carl
    roseville carl
    yep, but not at the strip.....makes starting it easier, don't have to prime da pump.......
  7. roseville carl
    roseville carl
    Test n tune in 11 days then off to Eagle in 59 days Yaaa Hooo
    fenderless likes this.
  8. 64 DODGE 440
    64 DODGE 440
    from so cal
    Are we there yet? ;)
  9. roseville carl
    roseville carl
    Getting there one step at a time 12.12 @ 109
    Hotrodmyk and Autodave like this.
  10. fenderless
    fenderless
    from Norway
    Looking good Carl:) You are getting there;) Remember, I have used 5 years on and off to get into the 9 sec. ET's;)
    Hope you post some from EF:) Oh, Who will be driving?
    I have looked and learned from Your earlier post on the sleeving part;) And some good heads up from Roy;)
    /K
  11. dragsled
    dragsled
    from Panama IA
    Congrates Carl,,,Great Video , Cool nite shots, Oh BTW even tho your grandson and I are years apart in age, We speak the same language :D:D:D:D Tim Jones
  12. roseville carl
    roseville carl
    Yea Tim he speaks the 18th edition of proper English Grammar as proposed by Grandpa.................Uh
  13. Unkl Ian
    Unkl Ian
    Carl: what ET was your ch***is certified to ?
  14. roseville carl
    roseville carl
    10.0 or slower no cert sticker needed, so I can't go faster then 10.0,... the magic no.
  15. Unkl Ian
    Unkl Ian
    Got it, thanks.
  16. roseville carl
    roseville carl
    Well finally got pissed enough at the ol seat cushion decided to do something about it......
    Old cushion... foam of absolutely no density..........
    New foam 2" of dense foam to park my fat *** on......
    [​IMG] [​IMG]
    Wood bottom to attach fabric to...........
    After a bunch of time on Momma's sewing machine WaLa............... a seat it ain't pretty but I hate upholstery work and I usually sew my fingers together and say words not in Webster's Dictionary...............so there...... and damn its comfortable......
    [​IMG] [​IMG]
  17. 64 DODGE 440
    64 DODGE 440
    from so cal
    Nicely done Carl. Should cut a tenth off your ET and everyone knows when your **** is comfy, you'll cut a better reaction time.:)
  18. fenderless
    fenderless
    from Norway
    Looking comfy Carl;) You are Lucky to be able to do it, I was forced to do the oposite, taking the foam out to have more clearence to the hoops;/ Damm uncomfy sitting in there, strapped Down waiting up to half an hour...;) On top of that I have straind tendons while in there, that is really uncomfy....;)
    /K
  19. dragsled
    dragsled
    from Panama IA
    nice work Carl, Still a man of many talents, Tim Jones
  20. roseville carl
    roseville carl
    Yea Tim but I still hate upholstery. Now I really have to work on a wheelie bar, last time out I spent way too much time in da air. The track had plenty of traction didn't have the camera on the first run when she went about three feet high and came down real hard and shorted out some wiring that I had to fix. Ran the last runs a little less aggressive off the line and still lifted the front end................
    CGkidd likes this.
  21. roseville carl
    roseville carl
    Well got some work done on the blower manifold ..................my buddy Ron put his magic touch on the welding and I am stoked...............plenum.
    [​IMG] [​IMG]
    Tacked the rest of the parts on so Ron can do his thing, a whole lot better than this ol codger...................
    but damn am I stoked at this so far!
    [​IMG] [​IMG]
    Even Ron Likes it!!!!..................
    Hotrodmyk and CGkidd like this.
  22. dragsled
    dragsled
    from Panama IA
    Looking good Carl, is your top going to be welded on? or will you bolt it, Tim Jones
  23. 64 DODGE 440
    64 DODGE 440
    from so cal
    Now you are going to need to build a periscope to see where you are going. :rolleyes:
  24. roseville carl
    roseville carl
    Gets bolted with allen headed tapered screws with plenty of Loc***e Tim I don't want to ruin the 4-2 manifold
    yea Tom if I need one, I will build it................
    CGkidd likes this.
  25. CGkidd
    CGkidd
    Just got done reading all 50 pages. Way cool.
  26. roseville carl
    roseville carl
    Thanks Eric, just wait about 18 days it gets way cooler.......................
  27. roseville carl
    roseville carl
    Finish welding on manifold.......I'm stoked
    [​IMG] [​IMG]
  28. 300racr
    300racr
    from Phoenix,Az
    Nice work on the manifold!
  29. loudbang
    Just wondering if you get much warpage when doing jobs that thick.
    1947knuck likes this.
  30. CGkidd
    CGkidd
