Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. old sparks
    old sparks
    Not well. As usual with me, every time I get full of myself something happens just to let me know how much I don`t know. Lost the ignition on the fourth p***. I think. I think I`ll change 3 or 4 things as usual so I`m really lost. I`ll still be at eagle field. Your fab skills are exceptional by the way
  2. roseville carl
    roseville carl
    lost ign should be easy to diagnose, didn't shear pin on dist shaft did you??
    Thanks for the compliment but just an old pipefitter who hates to spend money, with a lot of time on his hands....
    Hey if you are ever around Roseville look me up......
  3. roseville carl
    roseville carl
    Well getting closer.......upper bracket
    [​IMG] [​IMG]
    Before final touches, bending sanding ect........ used my CNC machine " Carls Nutty Creations machine"
  4. fenderless
    fenderless
    from Norway
    Good job Carl:) Sorry for my late replay, I can't find the pictures of the wheelie-bar set-up. But again yours looks really fine. Mine was built around the push-bar, and the excisting hole in the chut-tail. I'm done for the season as the block has way to many cracks;)
    /K
  5. roseville carl
    roseville carl
    Way too much Nitro huh Kjell......... too bad ya weren't closer I might have a block for ya...........
  6. dragsled
    dragsled
    from Panama IA
    Looks good Carl, " Carls Nutty Creations Machine " Beats useing a cutoff wheel and a file:D:D:D
  7. roseville carl
    roseville carl
    Well got the upper bracket bent today my brake wouldn't handle the thickness so had to get it done......
    and of course had to make extra gaskets and spares just in case we need um....... thanks mom for use of kitchen table its hot here today 108 degrees ug.............remind self , if I ever hit it big get garage air conditioned.......
  8. roseville carl
    roseville carl
    Well some days are better than others........
    Finished restraints........
    [​IMG] [​IMG]
    old fuel pump set up...... would work for the carbed version but not enough for the blown version........
    New pump......
    new bracket.......
    [​IMG] [​IMG]
    T&T next Friday!!!!!
  9. dragsled
    dragsled
    from Panama IA
    Looks Really nice Carl , Good luck next week, PS Turn the video Cam on:D:D:D
  10. CGkidd
    CGkidd
    Looks nice Carl
  11. roseville carl
    roseville carl
    Thanks Eric, ya got that Studie ready for Eagle??? ya know ya got a place to stay if ya need it.........
    Yea Tim I think I will spend some time looking at the GoPro directions;);)
    dearjose likes this.
  12. CGkidd
    CGkidd
    Well I was hoping to have more done but I rolled my ankle and was down for a couple weeks. Plus change of direction on transmission. Got a line on a original B&M hydro to go in place of the Muncie. Still a four speed just the trans does all the work.
  13. roseville carl
    roseville carl
  14. wrenchbender
    wrenchbender
    That's awesome carl Do you have the carb mounted backwards on that thing
  15. roseville carl
    roseville carl
    na the carb is correct the dragster is backwards
  16. dragsled
    dragsled
    from Panama IA
    Sounded Good Carl, Careful Dancing around on your trailer,:D you'll be walking around all hobled up like I am this week:rolleyes: Replacing the Clutch in our 4x4 truck kicked my *** ,
  17. old sparks
    old sparks
    [Good luck at test and tune. I made the mistake of pitting up by the staging lanes and found out that everyone else wanted to do the same. barely had enough room to move around the car. I won`t do that again. The tech guy really knows his stuff , but he is not a hard a.. . Have fun and let us know how it went.
  18. roseville carl
    roseville carl
    Yea I always pit out in the back 40 usually by myself, plenty of room.
    You gotta stop using the 4x4 as a race car Tim, Beth will win every time!!!
    Damn though looks like I could shave a few tenths off by getting rid of that damn Dunnlap............ ouch that ****s.
  19. roseville carl
    roseville carl
    Well T&T is over good news and not so good news..........11.272 at 120.53 blew trans gasket oiled down track ug....... engine was great running a little rich so plenty of room for improvement ........
    Ponti461 likes this.
  20. old sparks
    old sparks
    Sounds like some of my luck went your way. Are you planning another test session before eagle field? If so, I think I`ve got mine fixed and need to prove it. MSD doesn`t like solid core wires and non resister plugs.
  21. roseville carl
    roseville carl
    We will have to see what exactly the problem is this week some time and go from there, Sac wants me to add some more safety **** to the car also....... it never ends add something that requires more additions.......
  22. 64 DODGE 440
    64 DODGE 440
    from so cal
    What now? o_O
  23. roseville carl
    roseville carl
    More maintenance Tom, a belt guard on top pulley, and a cover over trans.... but she will be ready for Eagle!!!
  24. old sparks
    old sparks
    Just found a free test track for us Californians. Went to New Melones lake this afternoon and because of the drought there are no boat ramps to be used. There are two parking lots, each about 1/8 mile long, that are completely empty. Made 8 launches and shut off just before the shift point. Never thought I would have anything good to say about the drought. I`m ready for eagle field, see you there.
  25. dragsled
    dragsled
    from Panama IA
    Sounds like the test and tune went OK other than the trans problem,,, Safety stuff,, the cost of going faster:D:D, any video yet
  26. roseville carl
    roseville carl
    Uh two old farts couldn't figure out how too turn it on at the line again so no video.......Ugggggggggg:rolleyes::rolleyes:
    We really need to get that part of the crew up to speed........
  27. CGkidd
    CGkidd
    Seems to be a reoccurring issue with the camera. ;)
  28. roseville carl
    roseville carl
    Maybe its not the camera.........
  29. 64 DODGE 440
    64 DODGE 440
    from so cal
    Camera operator?
  30. roseville carl
    roseville carl
    Operators!
