Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. roseville carl
    roseville carl
    Well another weekend at Eagle Field is over, the Flathead/6Cylinder clash is completed, and man am I tired. I can only imagine how Rocky and all the crew who put in countless hours feel today. To Earl Boyajian, Lynn Gomes, AJ Thomas in the tower, I cannot thank you enough for your patience and tolerance with all us idiots out there. This wekend must have been trying on your nerves. Just remember that if it wasn't for your efforts those of us with different cars would not have a place to run our cars, and I for one, and speaking for all the Flathead/ 6Cylinder cl*** do truly appriciate all of the effort you made this weekend. Your efforts make it possible for this ol man to relive his youth thank you.................
  2. roseville carl
    roseville carl
  3. Harv
    Harv
    from Sydney
    A quick question please. I am in the process of building a FED (ch***is about 1/2 done, pulling together the rest of the parts), running a GM Holden inline 6 and powerglide. Intent is to be IHRA compliant so I can run at the local track. 150" ch***is. Not the fastest thing in the world (perhaps 11 seconds) but it will make me grin.
    Rear end will be Chev bolt pattern (5x120.65) on a Toyota Hilux axle. Forgive me HAMB.... I know I have sinned but there are few choices locally for a nostalgic axle that is not overly beefy or has limited ratios... this thing will run only about 200hp and a 9" or similar would be overkill.
    I'm thinking a set of American Racing Torque Thrust D's. They appear to make 14", 15" ad 16", though widths and offsets are relatively scarce except the 15".
    What size wheels and tyres are on your FED please, and what ch***is length? To me the proportioning looks spot-on.
    Cheers,
    Harv
  4. AmishMike
    AmishMike
    Problems with drag racing. The wait, then told to fire up, then told to wait while overheating… have u considered alcohol? Expensive but cooler - maybe..
  5. roseville carl
    roseville carl
    Harv my ch***is is 135" wheels are 28.0/9.0/15 Mickey Thompsons, I had some 12" s on her at the start but was way too much tire for the ol Flathead the 9's are way better. Oh a 3.42 rear end.....Carl
    Mike I spent about 4 years ****ing with alky and gave up last year and went back to gas........Carl
  6. Harv
    Harv
    from Sydney
    Thankyou sir, much appreciated.
    I suspect I will have the same over-tyred problem with my Holden grey motor. It will only pull 200hp (though that is a little more than the 75hp it came from the factory with :D).
    Cheers,
    Harv
  7. spanners
    spanners
    Gee Harv, I don't think they had 75h.p. on a good day. The manual I've got says 60.5.
  8. Harv
    Harv
    from Sydney
    60 ponies in a humpy. By the time the EJ came along, another 15 horses had been added. Mind you, many of those horses were driving the water pump, fan and generator. Not too many of them were out the front pulling on the harness.
    Cheers,
    Harv
  9. spanners
    spanners
    Beautiful video Carl. Have you thought of doing this stuff professionally?
  10. 1124jhh
    1124jhh
    from Auburn,CA
    Thank you Carl !
  11. roseville carl
    roseville carl
    hell I'm 77 and it takes me forever to make one, not monetarly feasable IMHO..........
  12. roseville carl
    roseville carl
    and yes Harv you will be disappointed with the big tires takes too much hp to move em IMHO
  13. roseville carl
    roseville carl
    your welcome.....
  14. roseville carl
    roseville carl
  15. Harv
    Harv
    from Sydney
    Many thanks - this is useful information. Still a few high-HP, blown FEDs out there, but very few of the lower-HP variety that I am aiming for. Finding practical info can be a challenge, and is appreciated.
    The 10" Torque Thrust D's are on their way, so I figure I'll run them for now. They may not be the fastest thing, but I'm guessing that they will look pretty good and keep me grinning like a Cheshire cat for a while.
    The diff is being positioned into the ch***is next week, but has yet to be narrowed. I've got the opportunity to set it up for multiple wheels, so your info was timely. The Torque Thrust Ds in Chev bolt pattern range from 2.16 - 4.5" backspace, so will make sure there is enough room to let me try out narrower ones (10" are 3.77" backspace, 8" are 4.5").
    Cheers, and thanks,
    Harv
  16. spanners
    spanners
    Hey Harv, what model Hilux diff are you using and what ratio and is it limited slip or open centre? I've got an Austin A40 cab/ch***is that's begging to be raced.
  17. Harv
    Harv
    from Sydney
    Austins is cool :cool: You thinking of something similar to the Oztin g***er?
    I'm running a Toyota G-series diff (8" live axle) from a HiAce. These are identical to a Hilux, but cheaper. The rock-crawlers are interested in the carriers, so the housings, crowns and pinions are cheap. They will handle 400-odd ponies with no problem, are a lot lighter and take less power to drive than a 9". The awesome bit is that they have a hell of a lot of ratios - factory has 41 crown and pinion options from 3.154:1 through 7.636:1. The G-series diffs come in a 2-pinion (40mm bearings, used in 4-cylinder vehicles) and beefier 4-pinion (50mm bearing - V6 Hilux's) option. I'm running the 2-pinion setup from the HiAce, with the carrier replaced by a spool from Nitro Gear (they do spools for both 2 and 4-pinion options). It'll get cut down to only about 3' wide (36" of diff and 20" of tyres :D), so some stumpy Mark Williams axles will get used. There is no chance in hell this thing will be under 7.5 seconds or over 2500lb, so the local interpretation of IHRA rules says that I don't need floaters.
    Fancy-*** diff for my motor that hales back to 1948 :p
    Cheers,
    Harv
  18. roseville carl
    roseville carl
    well another Flathead 6Cyl Clash is in da books....................
    Blues4U, HiSpoke and Bandit Billy like this.
  19. Bandit Billy
    Bandit Billy
    That was fun! Well, other than the mayhem.
  20. spanners
    spanners
    Love your videos Carl. Hopefully no other damage besides the blown tyre? Was it a front or rear?
  21. roseville carl
    roseville carl
    front 20 year ol radial, replacing all 4 SOON, I'm more worried about the dragster front end........
  22. spanners
    spanners
    Yes, what happened there? Were you being towed and ran up the rear of your truck?
  23. roseville carl
    roseville carl
    Old man makes stupid mistake hits tow vehicle trying to get to line...........OOOPPPS this was first thing saturday before we even got started, she ran perfect friday and I quess I was a little to anxious to get going saturday. Was unhooked and thought I had enough room to clear NOT. Well now on to axle straightning cl***.................UGGG
  24. spanners
    spanners
    No, it's not an old man mistake. Blame the pit crew for reversing into you.:D
    Old6rodder likes this.
  25. roseville carl
    roseville carl
    can't do that he would get pissed and then I wouldn't have a pit crew.......:rolleyes:
    64 DODGE 440 likes this.
  26. 64 DODGE 440
    64 DODGE 440
    from so cal
    Hope it's an easy repair. It didn't look like a lot of parts got bent.
  27. roseville carl
    roseville carl
    Well Tom not as bad as I first thought, axle is 3degrees off. I think i can get er back by the drag links, replacing all the hardware for new stuff, can't be too careful!
    turning 1/2 pipe pins:
    OahuEli and 64 DODGE 440 like this.
  28. roseville carl
    roseville carl
    well after a day of futzin and banging around we got er to within 1/2 degree, now on to some structual plates on the wishbones and all will be well in flathead land.........
  29. 64 DODGE 440
    64 DODGE 440
    from so cal
    That's what we have big hammers for Carl. Looking good.
  30. Old6rodder
    Old6rodder
    from SoCal
    Ch***is work's always fun & games. :rolleyes:
