Technical Flat glass installation
Discussion in 'The Hokey Ass Message Board' started by Dogger, Aug 21, 2024.
  1. I am looking for a gl*** person to install gl*** in a 37 Chevy coupe…..
    It is all new flat gl*** and new steel rubber gaskets.
    New door gl*** tracks.
    I am in the Waco area but will travel to DFW or Austin area if I can make an appointment to get it done in a day…..can leave car if absolutely necessary.
    Can text me with info.
    Thank you!-Dogger
    8one7-296-951one
  2. 19Fordy
    19Fordy
    I know you said you want it professionally installed. However (on my 40), I found you can do it yourself if you take your time and have patience. Just for the heck of it check on-line for DIY videos.
    Keep in mind gl*** date codes and tint as well as laminated safety gl***.
    tractorguy likes this.
  3. Ok I will look into that.
    Gl*** is a new kit from Bob’s so will be good.
    Thanks for the suggestion!
  4. 51504bat
    51504bat
    If you do decide to do it yourself, do not lube the rubber gasket with WD 40 when you install the gl*** in it. Only use window cleaner per the guy who cut the gl*** for my '39 p/u.
  5. 325w
    325w
    This kid does gl*** in Fort Worth area lance Morris 817-845-5721. Seen his work it’s good.
  6. willys36
    willys36
    I just did my '40 Plymouth a couple months ago. Nice to have a helper when doing the job. Lube with soapy water, pretty easy work.
  7. Thank you f
    or info…. I called him and he no longer does old car gl***.
  8. 51504bat
    51504bat
