1952-59 Ford flat head 2 blade fan?
Discussion in 'Off Topic Hot Rods & Customs' started by trimless, Jan 11, 2011.
  1. trimless
    trimless
    i have a 53 ford with a flathead v/8 and i would like to replace the two blade fan with a new multiblade one. problem is the old one is riveted on. has anyone replaced one?
  2. Retro Jim
    Retro Jim
    Cut the rivets .
    Jim
  3. missysdad1
    missysdad1
    I haven't checked yet, but you might look at Speedway Motors for a cure. They handle a lot of flathead aftermarket parts including ball bearing water pumps, etc. They might have just what you need. I just got a new catalog today, so I'll look tonight and see...
    Edit: Speedway sells an adapter to mount a 4-bolt fan to a modern GM alternator which mounts center/front as did the original generator. Neat way to kill two birds with one stone.
    I've got a Ford tractor fan with many blades in my parts stash that might fit your flathead. Please post photos and dimensions of your setup. No way to figure it out otherwise...
