flat head fan
Discussion in 'The Hokey Ass Message Board' started by joee, Aug 28, 2012.
  1. joee
    joee
    probably a 302 comming soon
  2. 36tbird
    36tbird
    The Streetrodder on the stands now has an article on the fans.
  3. joee
    joee
    air temp is 75 car ran 175...........
  4. hombres ruin
    hombres ruin
    thats a beautiful flathead spitfire!
  5. Straightpipes
    Straightpipes
    Biggest thing I do is clean the block as clean as possible. I've built quite a few and most have lots of casting sand and crud.
    Then, when you get it together set the timing properly.
    I'll have some truck fans at Hershey
  6. joee
    joee
    i spent a lot of time flushing the system and the timing is set on the mark.
  7. 36tbird
    36tbird
    You might do a search on using vinegar to clean everything out.
    There has been a lot of discussion that when you build a flathead, you need to stand it on the front end, poke the water p***ages, pressure wash, beat the block with a rubber mallet to dislodge the sand and crud to fall out of the water pump holes. If you missed the opportunity to do that, then flushing it out may or may not yield success. There has been a lot of discussion about the merits of different radiator flush chemicals, too. The times being what they are, a lot of the over the counter chemicals are not as potent as they used to be.
  8. joee
    joee
    well i just bought a 351 w....that'll slove my problem and i'll have enough hp to run air !!
    but thanks to all
