flat head ford
Discussion in 'The Hokey Ass Message Board' started by poco, Jun 25, 2024.
  1. poco
    poco
    from oklahoma
    Has any one had the push rod that works the fuel pump on a 8ba 50 model ford flat head wear enough that it would not work the pump? Don
  2. poco
    poco
    from oklahoma
  3. gary macdonald
    gary macdonald
    Never had the rod but usually its the fuel pump link .
  4. poco
    poco
    from oklahoma
  5. guthriesmith
    guthriesmith
    Might want to ask this on the main board since it would be very on topic Don. Or, maybe one of the moderators could move the thread over there.
    Tow Truck Tom and SS327 like this.
  6. Petejoe
    Petejoe
    from Zoar, Ohio
    A worn rod will definitely prevent the pump from applying enough pressure.
    With the many styles of afternarket intakes that mount the fuel pump at different heights will also cause this issue.
    Mount the rod and measure the maximum travel. Compare it with the distant needed to fully push the pump arm.
    Many have welded heights to make the rod long enough.
    clem, Tow Truck Tom and leon bee like this.
  7. RonaldR
    RonaldR
    Back in the day, just cut a piece of leather, and put it under the pump.
    greener200, clem and Petejoe like this.
  8. samurai mike
    samurai mike
    my dad told me that they used to put a penny in the pump. is this possible?
    clem likes this.
  9. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Questions like this are handled daily on The Ford Barn 'Early V8' forum.
    Go ahead and sign on. They are not neither averse or snobs to performance mods.
    What ever it takes to make flat head power.
    The rest of the car ( body ch***is ) they prefer original.
    Ask, you'll find answers you need.
    greener200, Kelly Burns and Petejoe like this.
  10. clem
    clem
    Yes, so I made an adjustable one, from the left over part and a bolt.
    I got told that it would not work, so instead of discussing that, which incidentally is still working, try this……...
    https://www.speedwaymotors.com/1949...d-for-Flathead-V8-10-062-Inch-Long,52292.html
    I have also heard about the coin or washer put under it, - an old timers trick.
    Petejoe and guthriesmith like this.
  11. chevyfordman
    chevyfordman
    I put a washer on the rod on my 52 Marc, never did have to change the fuel pump.
  12. sunbeam
    sunbeam
    they used to build them up with br***
    Petejoe likes this.
  13. Lost in the Fifties
    Lost in the Fifties
    When I was a teen, an old mechanic welded onto the end of the push rod, then ground smooth. Welded part installed up, and I had fuel again. I never had a problem in the next year I had the car!
  14. Flathead Dave
    Flathead Dave
    from So. Cal.
    The rod does wear down. I would also rebuild or change out the fuel pump, especially if it's the original pump.They're not very expensive and a new rod is around $20, depending on where you get it from.
  15. poco
    poco
    from oklahoma
    New parts ordered, we will see. Don
