Flat paint question
Discussion in 'The Hokey Ass Message Board' started by wademp, Mar 29, 2009.
  1. wademp
    wademp
    If you paint a car a base coat/clear coat and put flattening agent into the clear coat do you still have to wet sand and buff when you are done?
  2. motoandy
    motoandy
    from MB, SC
    If you have orange peel in the clear, you can still wet sand. You can apply a few coats of the flattened clear then sand till smooth.
  3. SlowandLow63
    SlowandLow63
    from Central NJ
    No. Matter of fact you can't buff. Buffing the flattened clear will put the shine back into it. You can sand out any imperfections and reshoot it, but it has to be right when it comes out of the gun.
  4. bbc 1957 gasser
    bbc 1957 gasser
    if you want it smooth and no dirt after you buff it if will still be flat did a 69 mach 1 like that ..used dupont chromabase ..
    also have done it with enamel and flattner ..
  5. Customs&Color
    Customs&Color
    The good thing about the flat clear is that dirt/trash in the paint won't be very noticeable. You don't need to spray the flat clear as heavy as normal either. A couple of medium coats and you should be good, remember the more clear you put on the shinier it will get.
  6. wademp
    wademp
    Thanks guys.
