Flat tie rod arms vs standard Ford arms
Discussion in 'The Hokey Ass Message Board' started by 27tbone, May 22, 2008.
  1. 27tbone
    27tbone
    Anyone know if there is a reason to run flat tie rod arms instead of standard Ford arms for this setup? I have a spring behind dropped beam axle with split wishbones, suicide perch, aftermarket 40 style spindles, 40 backing plates and reversed Corvair box with traditional steering. I was ready to pull the trigger on a set of Speedway Ford arms but they state that they are only recommended for cross steer and spring over axle. Is it a clearance issue?
  2. Fogger
    Fogger
    Are Speedway's forged? Check with Chassis Engineering theirs are forged. Get the best you can for steering and brakes. The FOGGER
  3. 27tbone
    27tbone
    Thanks for the reply Fogger. I checked with Speedway and their tie rod arms are forged, the issue has to do with conflicts with the spring on their T chassis kit. Since I am building my own chassis, I think I'll be ok. I think the old Ford type arms look a little better than the flat ones, but that's just me.
