Hot Rods Flat Top Perches
Discussion in 'The Hokey Ass Message Board' started by jonsu2, Jan 13, 2011.
  1. jonsu2
    jonsu2
    from nj
    Is there anyhting wrong with using grade 8 bolts and nyloks instead of the expensive perch bolts from Speedway or simillar companies.
  2. F&J
    F&J
    Bolts and nuts won't have the tapered seats that keep it all tight and aligned.
  3. lowsquire
    lowsquire
    from Austin, TX
    If you can make some tapered cone washers for the seats in the wishbones on a Lathe it might be a cheaper way to go..
  4. Get some stock pins and machine the tops off. The "shank" of the perch is an odd size.
  5. jonsu2
    jonsu2
    from nj
    I guess that answers that question. Thanks
