Technical flat towing after rear rebuild
Discussion in 'The Hokey Ass Message Board' started by topher5150, Feb 3, 2021.
  1. topher5150
    topher5150
    So I got my diff rebuilt about a year or so ago, haven't put any miles on it other than moving it around the yard. I wanted to get it towed to have some work done on it and was thinking about using a car dolly maybe 5 or 6 miles. Would it hurt anything doing it this way or should I trailer it?
  2. fresh hops
    fresh hops
    If the rebuild was done right and you have gear lube in the rear end, you should be fine to tow it 5-6 miles
    loudbang and topher5150 like this.
  3. TheSteamDoc
    TheSteamDoc
    It'll be fine. Make sure its topped off.
  4. oldolds
    oldolds
    You should be fine. Does the car run? Maybe put it up in the air and Run it a little bit to throw some oil around with no weight on things. Just be advised that it is a dangerous thing to do. Things can go wrong quickly.
  5. greybeard360
    greybeard360
    Pull the driveshaft if it's an auto trans.
    loudbang and stillrunners like this.
  6. sunbeam
    sunbeam
    You can put the rear wheels on the dolly
    loudbang and lippy like this.
  7. jaracer
    jaracer
    Your rear axle doesn't care if it is being driven by the pinion gear or the rear wheels. Everything inside turns the same and the ring gear acts as an oil pump distributing lube to all the bearings. A potential problem is if you have a transmission connected to the rear axle. Manual or automatic, you can damage the transmission by flat towing.
    loudbang and RJP like this.
  8. topher5150
    topher5150
    -I think I put about two things of oil in
    -No drive shaft yet.
    57 300
    from 211 Maple
  10. hemihotrod66
    hemihotrod66
    In the 70's I flat towed a 34 Ford with the original drivetrain in neutral from Dayton Oh to Clovis NM on the interstates and had no issues...
  11. 1971BB427
    1971BB427
    from Oregon
    I've flat towed my Austin to the drags 80 miles away numerous times. No issues ever.
  12. COCONUTS
    COCONUTS
    Has anyone ever heard of a 58 Chevy powerglide with a rear pump. You can push start the car, as you would a standard or turn the inners of the transmission if you were towing with the trans in neutral? You could lock the car on a slight hill in gear with the engine compression holding the car in place.
    loudbang and rusty valley like this.
  13. I flat towed my '60 Corvette all over the East Coast......removed the drive shaft from the rear and tied it up. Never had any issues with the POSI differential.
  14. 302GMC
    302GMC
    from Idaho
    Pull it regardless of what trans it is ...
    Didn't all iron Powerglides have rear pumps ?
  15. Budget36
    Budget36
    New gears or old gears and new stuff inside? If new gears I wouldn’t do it, in my thinking when towing, the ring and pinion would be constantly on the coast side, but either way the gears wouldn’t be “broken in properly “. If used gears, no issues I could see. Bearings getting oil is all that matters.
    Edit: a few miles your talking about just do it.
  16. stillrunners
    stillrunners
    from dallas
    Flat towing was my choice even after I got a trailer.....usually pull the driveshaft for long distance but sounds like you have that covered.
