Projects flathead 471 blower/supercharger
Discussion in 'Traditional Hot Rods' started by Ed95, Jan 22, 2026.
  1. Ed95
    Ed95
    Hello everyone!
    I've been working on my 8ba flathead for the past year or so and have finally set up everything in a way that works well, so in my head that meant I need a blower to mess it all up again. I just purchased a 471 blower with new rotors and new gears; it also has front and back plates and its been converted for gas use... Got a decent deal.
    So, the search for parts commences. I want to set it up as old school as possible. I plan to make between 4-6 PSI boost. I wasn't necessarily trying to spend a fortune. I have a good block but haven't spent that much time on internals.
    I found a MUNRO intake manifold online for around $700 and some snout options but still not sure about how this should all be set up. I heard some people prune their case (for looks I ***ume?). Honestly if it all fits, I don't care much about that. I also figured it would be smart to know my rpm's when setting this up, so I purchased a tachometer to hopefully make things easier for myself. I plan on running my dual holey 94's on top of the blower (hopefully that's enough) and would like to use v-belts. I expect I'll need 2 belts for the blower and another for accessories. I don't have a lot of space but would love to keep my mechanical fan somehow. If anyone's already set this up, I'd appreciate some advice/tips... I've never messed with blowers before, so this will be a fun experiment.
    here’s my flathead
    and this one here is one i found online with a 471 blower. Looks awesome
    1pickup, chlsnk, Rehpotsirhcj and 9 others like this.
  2. 3blapcam
    3blapcam
    This ought to be good... I'll be watching! ;)
    FWIW, I think H&H has snouts & possibly pulleys.
    3blap.
    Tow Truck Tom, Sharpone and Ed95 like this.
  3. wheeltramp brian
    wheeltramp brian
    You have a 4-71 and in the car pictures it's a 4v71.differnt mounting.
  4. 19Eddy30
    19Eddy30
    from VA
    @Bandit Billy ! ? "Fan"
    Pic shown it's look's
    To be 1:1 pulleys .
    Whats your static compression?
    If static is 7:1 with 1:1 ratio is around close to 13 psi boost (4:71)
    = compression ratio total will be close to 13:1 ,, I do not think 2 94's enough CFM ,
    a 94 are like 160 -180 cfms
    You would need about 25 percent under driven top pulley to make roughly 6 psi boost,
    On 7:1 static compression with 6psi will = 10:1ish under boost
    2 94 should be enough
    I think with thought you could squeeze a mech fan in there with 2 v belts.
    Or even 1 inch belt ...
    It would be a custom made bearing stand pulley with fan.
    Or turn around the blower face it backwards run a drive shaft down the side to drive the blower belt off V belts
    Or a 1 inch ,,,I think outside the box, I think the new blowers on the Camaro are done this way blowers are backwards with the dry shaft
    weps, Tat2Neil, Tow Truck Tom and 6 others like this.
  5. Flatrod17
    Flatrod17
    My brother's car I am building for him. I pruned the case because of the water manifolds, and he wanted the 2" belt. Custom alternator brackets. No room for mechanical fan.
  6. Tim
    Tim
    from KCMO
    The roadster with the blower is Carly Moodys I’m pretty sure.
    She posts a lot online but I bet this video would have clues.
  7. Ed95
    Ed95
    Yup! I'm basing my build from hers a bit but not going pink on the block haha. and I may not prune it if it all fits. I wondered if I could do 1 v belt on the blower since im gonna be underdriven quite a bit but dont want to slip obviousy
  8. 19Eddy30
    19Eddy30
    from VA
    Yes with the correct belt for
    contact / grip unload , just examples many more options in Vs IMG_4753.png
  9. Ed95
    Ed95
    thanks @19Eddy30 you seem to know your stuff! what establishes proper contact/grip unload?
    Tow Truck Tom and Sharpone like this.
  10. Bandit Billy
    Bandit Billy
    Are you asking if I am a fan or what did I do for a fan? I am a fan of blown flatheads but alas I used an electric fan to cool mine. Not that anyone can see it buried in there so I don't worry about it.
    Mine is pruned (less is more?), it is a tight fit with a non-pruned (bushy?) 471 but it can be done I suppose.
    I do suggest spending a bit of time porting, relieving and dialing in the QR. And do spend some money on mains.
    You can just catch a glimpse of the fan here. It is buried in a br*** and German silver shroud where it has been doing its job nicely for several years.
    Toms Dogs, ronzmtrwrx, weps and 10 others like this.
  11. squirrel
    pictures of a 3-71 with pruned case, and mechanical fan, for your enjoyment. 2 V belts isn't much for a 4-71.
    1pickup, weps, Deutscher and 8 others like this.
  12. 19Eddy30
    19Eddy30
    from VA
    @Ed95
    Angle /deg of V , size of belt , & how much contact surface of Belt V to
    pulley V, you can look up spec's for this,
    Best to use Industrial/Commercial spec's information.
    @Bandit Billy you where one of that I thought of for B-FH's , probably had more knowledge of maybe how to
    run /set up mech fan on a Blower .
    My self I am sure I can fabricate & machine parts to accomplish.
    I have a roadster it has a FH now ,
    I do not know if I am going to change direction keep the FH add one of the blower's , 4 bang , Jap straight 6 , 406 427 sb, & parts for close to 500 cid sb ,
    BB's , 455 Buick , I have many other
    brands & combo's
    Deutscher, Tow Truck Tom and Sharpone like this.
  13. Ed95
    Ed95
    With my Edelbrock heads compression should be more around 8:1, but maybe a bit less. I have STD bore and stock 8ba cam
  14. 19Eddy30
    19Eddy30
    from VA
    By Looking @ previous pics I came up with another thought ,
    You could make in a way & use the
    Blower belt Idler to attach a fan to,
    Also & depends witch way/ Direction you run / route belts would determine which style fan to run so it pulls air,
    & you could run correct length belts to center in the middle of the radiatoro_O
  15. 19Eddy30
    19Eddy30
    from VA
    30-35 under drive top pulley %
    @ 8:1 plus 6 psi = roughly 12:1 under boost.
    & iffy know on 2 94's
  16. JimSibley
    JimSibley
    I am running a mostly stock bottom end, 3-71, flipped upside down, and pruned. Makes 200 hp and has ran low 8s in the 1/8 mile drags, 12s in the quarter. IMG_1013.jpeg
    Toms Dogs, 1pickup, Enbloc and 11 others like this.
  17. 19Eddy30
    19Eddy30
    from VA
    Nice looking simple Race Rod ..
    1,800 pd's?
    Light also help's Not that much load on engine
    Tow Truck Tom, Sharpone and mad mikey like this.
  18. JimSibley
    JimSibley
    1540 with me in it.
    Ziggster, Deutscher, rod1 and 4 others like this.
  19. 3blapcam
    3blapcam
    Did you flip it so that it fits better? Please advise.
    3blap.
  20. Ed95
    Ed95
    Whats the formula? How do you determine pulley ratio and how do you know if the dual 94s is enough or not?
    Tow Truck Tom likes this.
  21. 19Eddy30
    19Eddy30
    from VA
    Just a few examples chart's & math..
    The calculated numbers BELOW
    Does Not apply
    For your FlatHead just examples of other ways to calculate ,
    Blower Cid
    Pulley ratios
    Blower speed
    Etc..
  22. JimSibley
    JimSibley
    The blower was recycled from a drag bike, they set it up that way and we just repurposed it.
    Tow Truck Tom, mad mikey and 3blapcam like this.
  23. 3blapcam
    3blapcam
    Interesting. Thanks for the response!
    3blap.
  24. tim troutman
    tim troutman
    my buddy **** Face used to say I have paid my dues to flat heads ran over a few crankshafts blown flat head.jpg
    GuyW, 1pickup, weps and 4 others like this.
  25. 3blapcam
    3blapcam
    Oh man... that chain drive is nuts! Cool looking rig... any more pics?
    3blap.
    weps and Tow Truck Tom like this.
  26. tim troutman
    tim troutman
  27. tim troutman
    tim troutman
  28. Fordors
    Fordors
    That negative was flipped, that blower wouldn’t make much boost pushing the air down the middle.
  29. gimpyshotrods
    gimpyshotrods
    It's not.
    That is a pruned 4-71. The bottom flange has been removed.
    Like so.
  30. 19Eddy30
    19Eddy30
    from VA
    What the purpose to Pruned?
    Cleaner look
    Was done when a intake was not made for the outer mounts's ?
    Seem weaker with bolt's moved in ward
    As in not a wider anchoring point's.
    Leverage to twist.
    In post # 11 The idler not best to have on Left side for Clock Wise rotation .
    Post # 26 thats unique way to drive the blower off the F-H water pump to a certain extent.
    @JimSibley was the end plats reversed so air trapped in between case and lobe
    Or
    Air straight threw center
    & out the center ?
