Flathead 5 speed
Discussion in 'The Hokey Ass Message Board' started by tjelwood, Oct 25, 2006.
  1. tjelwood
    tjelwood
    from oklahoma
    Does anyone make an adapter to use the world cl*** 5 speeds that you would find in a 94 and later s-10. I have one of these ******s laying around that I would like to put it behind the flathead in my 50.
  2. flatoz
    flatoz
    do a search,
    topic has been covered heaps of times.
    I think cornhusker does a kit for that box.
    but use the search, it is your friend.
  3. tjelwood
    tjelwood
    from oklahoma
    I know that cornhuskers kit is for the 93 and earlier ****** because I thought that I was gonna be lucky enough to use that ****** behind my 35 flathead that I am putting in my 35. I have decided to keep the 50 and I want to be able to jump in it and go because right now I am limited to about how far I can go because I am not a big fan of cruising around at 50mph and getting 10 miles a gallon these days can get expensive.
  4. racer5c
    racer5c
    Got mine at Speedway, Offy makes em
  5. 50 Ford 1963
    50 Ford 1963
  6. krylon32
    krylon32
    from Nebraska
    The company that makes an adaptor for your trans is I think called Shadow Rods out of Michigan.
  7. Ole don
    Ole don
    Make your own for about a hundred bucks. Dirrections are in "Member articles", on Fordbarn.
  8. flatheadpete
    flatheadpete
    from Burton, MI
    Run in part by Mark Kirby....Motor City Flatheads. They'll know . I used the Offy adaptor. Works like a champ.
  9. 8flat
    8flat
    Flat-O products makes one too, he's a knowledgeable guy running a little one man show.
  10. krylon32
    krylon32
    from Nebraska
    Cornhuskers kit is made for the GM pattern S-10 trans 85-92 and Shadow Rods is for a Ford pattern as I believe the later 93 up S-10 trans have. I could be mistaken.
