Hot Rods flathead 6 Dodge trans question.
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Jul 14, 2017.
  1. rusty rocket
    rusty rocket
    What should a guy look for to put a top loader trans behind a flathead six? I'm ***uming a pickup. I'm piecing together a single seater and have access to an early 50s Dodge 6 but it has an auto behind it. I'm thinking car trans had side shift but a top loader would work the best for my application. Help me MOPAR GURUs.
  2. Hnstray
    Hnstray
    from Quincy, IL
    a Ford Ranger/Mazda pickup 5 speed from the mid '80s is a fairly easy adaption to the Plymouth/Dodge short bell housing (Dodge thru '54 is long). There was a guy here on the HAMB who did that a couple of years ago on his '49 Plymouth. A search 're '49 Plymouth would probably turn it up. As I recall, it was an aluminum plate drilled for the bell housing and transmission with an appropriate center bore...etc.
    Ray
  3. rusty rocket
    rusty rocket
    Thanks,
    I'm trying to keep it TROG worthy. I will never get out that way but want to keep the car all late 40s/early 50s era.
    Sorry should have mentioned that in the ***le.
  4. 302GMC
    302GMC
    from Idaho
    Pre-war Dodge or Plymouth stuff for the bellhousing & trans. Desoto & Chrysler offered floor shift OD until '38. Dodge truck for the clutch & flywheel if used hard ... all that Chrysler running gear bolts together if you have the right combo. The '38 Imperial trans was reputed to be as strong as a Packard or Buick.
    Frankie47, Joe Mammana and Hnstray like this.
  5. Bobacuda
    Bobacuda
    DO NOT get the standard trans setup from a Fluid Drive. You will not be happy with it for your use. Go to http://p15-d24.com/ and tell the folks what you are doing. You will probably be able to trade your automatic setup for what you will need.
  6. rusty rocket
    rusty rocket
    Thanks for the info guys. I will look into the p15 d24 site.
  7. john worden
    john worden
    from iowa
    I might be missing something here but wouldn't a 3 speed manual top loader out of the era dodge/plymouth cars and trucks work for you?
  8. rusty rocket
    rusty rocket
    Dont know **** about Dodges, Im ***uming the cars had side shift for the column. If its anything like a Ford I should be looking for a truck. Thats why I'm asking.
  9. john worden
    john worden
    from iowa
    Dodge cars to at least 36 had top loaders and dodge/ply. trucks to at least 47 were top load.
  10. Latigo
    Latigo
    My '36 plymouth is a top loader. As mentioned, go to the P15-D24 site. A wealth of info and very knowledgable folks.
  11. 302GMC
    302GMC
    from Idaho
    Chrysler Corp went column shift in 1939, '39 Ply. Road King may still be floor shift. As answered above - any floor shift MoPar trans from '35 to '38, or 3 speed from a truck is what you're looking for.
  12. Are the 217 compatible with 230s as far as the bellhousing mounting up?
    Sent from my SM-N960U using The H.A.M.B. mobile app
  13. tub1
    tub1
    from tasmania
    Early 50s pickup 3 speed trans is the go I've used them
