Flathead 8BA Distributor - Mallory or MSD?
Discussion in 'The Hokey Ass Message Board' started by gearhead695456, Jun 11, 2013.
  1. gearhead695456
    gearhead695456
    Shopping for a 8BA flathead distributor........should I do an electronic or dual point for the distributor? The MSD electronic is a vacuum advance which heard is a draw back with the multiple carbs. The Mallory is electronic with no vacuum advance, but Ive also heard some so-so stuff about Mallory. Anyone had experiences with either?
  2. A Mallory distributor with Pertronix insides works well for me.
  3. 29AVEE8
    29AVEE8
    I have used the "old" Mallory full centrifugal duel point years ago and it worked very well on a multi carbed 8BA. I have heard anecdotal reports that the current production Mallory distributor may come with an SBC advance curve. In which case you would have to have it recurved. I have not used an MSD for a flathead, although I have one on a BBC in my boat and it has been problem free. I believe the flathead MSD is dimensionally larger than the Mallory.
  4. junk yard kid
    junk yard kid
    Hands down you want a gmc bubba dizzy. Looks better, runs better, easy to work on if you get points and its cheaper. Just search it on here.
  5. Yup! What he said, and it still looks more like a stocker.
    Here's a link: http://www.lindertech.com/bhrs/flathead_chev.htm
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    The Mallory electronics are more sensitive to voltage spikes than MSD. There is anecdotal evidence that the unilite module can't live with a generator and mechanical voltage regulator. You can run a filter with it, but at that price, you may as well go MSD. Don't let the vacuum advance scare you away.
    Alternatively, the old style Mallory looks good and the dual points can be replaced with a pertronix for electronic reliability. Getting the old flat caps can be challenging and expensive.
    A GMC bubba converted distributor is the best bang for the buck though, particularly for a daily driver.
  7. justpassinthru
    justpassinthru
    I have an MSD in my 8BA with 2 carbs. The vacuum advance is removable, mine is removed and curved like a mechanical advance only. I did have an issue with the drive gear on the distributor fitting too tight on the cam gear so I used the one from the original dist. The id of the original gear is about .002 bigger than the MSD gear, but seems fine. I also changed to a black cap. I like the MSD distributors due to the ease of tuning the advance curve.
    Bill
  8. gearhead695456
    gearhead695456
    Thanks guys, I just bought a bubba's dizzy.
  9. Kona Cruisers
    Kona Cruisers
    x2!
  10. kendall66
    kendall66
    from iowa
    I am running the MSD dizzy with no problems, had to do the tinkering with the advance springs......over all, very pleased.
