Technical Flathead 8BA oil pressure
Discussion in 'Traditional Hot Rods' started by lufsdastuf, Nov 15, 2019.
  1. lufsdastuf
    lufsdastuf
    from Detroit
    I don’t have any oil pressure in this Flathead 8BA. I pulled the engine and found that the gear on the end of the camshaft is spinning on the camshaft so none of the gears are spinning. Would I be okay to just tack weld the gear so it’s fixed to the cam or should I do something else. IMG_0191.JPG
  2. Flathead Dave
    Flathead Dave
    from So. Cal.
    Replace it.
    Don't tack weld it.
    Truckdoctor Andy likes this.
  3. treb11
    treb11
    Better dis***emble and check everything if run for any length of time without oil flow.
    Sent from my SM-G965U using The H.A.M.B. mobile app
    Flathead Dave likes this.
  4. lufsdastuf
    lufsdastuf
    from Detroit
    Yea, I pulled the oil pan and looked at everything from underneath. Lots of sludge in the pan, about an inch deep. I think I’ll just clean it out good and put a new oil pump in.
    I’m only using this stock engine to test drive this roadster for the first time and then I have a rebuilt flathead with a blower that’s going in.
