flathead adapter issues
Discussion in 'The Hokey Ass Message Board' started by sjrodder, Sep 29, 2010.
  1. sjrodder
    sjrodder
    from vermont
    need some help, im looking to adapt a 1993 bw t5 with the ford bellhousing bolt pattern to a flathead, does anyone know where i find an adapter to do this?
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    Macs Speed
    Vern Tardel
    Adapt a stamped steel 49-53 bellhousing
    Check the T5 Tech in my sign line...
  3. sjrodder
    sjrodder
    from vermont
    thanks for the info, looks like macs has the right one
  4. Shaggy
    Shaggy
    from Sultan, WA
    that should be a bolt up right?? no adapting nessicery
  5. Jimmy2car
    Jimmy2car
    from No. Cal
    Also try Gene Sanders in Akron, Ohio (MEC). Google Model Engineering Co. Makes nice stuff.
    Jim
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    modernbeat claims to have done it successfully with various minor t******* of the input pilot. I've not personally done it. As I understand it, two holes line up, one gets redrilled, and an ear must be welded on for the 4th hole...
  7. Shaggy
    Shaggy
    from Sultan, WA
    Ok i didnt realize stuff had changed since '64, my dad has a topload behind his
  8. Flat Ernie
    Flat Ernie
    Tech Editor
    '49-64 (except Falcon) all the same. '65-up got a newer pattern in use through the '90s?. Most of the early Toploaders had both bolt patterns. The T5 has a different pattern again...won't bolt up where a Toploader was.
  9. Shaggy
    Shaggy
    from Sultan, WA
    Okay damn, it's been a few years, apparently i got mixed up, thanks
