Projects Flathead Air Cleaner Choice
Discussion in 'Traditional Hot Rods' started by flat-ed, Jan 24, 2021.
  1. wandi harry
    wandi harry
    The filters that l am running ,can get part numbers if you wanted, they seem to work well
    34926501-3FEC-4D36-9CA0-A512F7064B46.jpeg A286A56C-464B-4F8D-B6C5-DCF05AF18F17.jpeg
  2. ydopen
    ydopen
    Here is my 276 with K&N filters sized to flow.
    John
  3. Garpo
    Garpo
    Read something in a tuning book a long time back. Recommended that each filter should have a capacity at least equal to one engine cylinder
    On that theory a flathead should have room in there for a large can of beans.
    Paper element on my wee 4bbl is about 6" i.d. x 4" high. Many runs on a quiet road with a gas ****yser, readings all in the green mid range, so I ***ume thats big enough.
  4. ydopen
    ydopen
    winduptoy likes this.
  5. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    K&N makes an oval filter for these carbs. More filter area than the round ones. Overall, though, I don't think that much of their filters. I'm thinking of fabricating my own to use taller, larger paper filters. Get rid of those helmets.
  6. jimmy six
    jimmy six
    If your going to have it on an enclosed hood I would think outside the box. I’d find a 60’s Chevrolet large round ac unit with some type of snorkel. I prefer an oval. I would fabricate a new bottom using the outer few inches for the filter fit. I’d sink it partially over the carbs. Chrome the top or even black depending or the rest of your engine compartment.
    Budget36 likes this.
  7. Nominal
    Nominal
  8. Budget36
    Budget36
    ^^^^^ Cl***y would have been to leave the Campbells wrapping on them.
  9. hipojoe
    hipojoe
    jimmy six likes this.
  10. Garpo
    Garpo
  11. winduptoy
    winduptoy
    To fit under the hood with it closed
    Early MJ (Jeep) air horns and filters for road driving.
    You can put the helmet style back on at the show
  12. 38bill
    38bill
    from Minnesota
    Been running these for some years but I have found K&N filters (SU-7503) that are the same dimension except twice as tall @4.5" that I may try. May not be the best but it should be better at twice the surface area.
