Customs Flathead alu heads advice
Discussion in 'The Hokey Ass Message Board' started by gurrru, Mar 31, 2026 at 2:19 AM.
  1. gurrru
    gurrru
    hello,
    I bought second-hand Offenhauser cylinder heads for my 53 Ford Customline. Now I need your advice.
    -Can I need these heads like that? should I let the heads be straightened again (sorry for my English but I don’t know the exact word) it looks like this has been done before
    -I don’t know exactly the condition of the heads. I don’t know whether the heads were ground several times. how exactly should I proceed here?
    -What type of seal do you recommend?
    Thanks for your help. cheers from Switzerland.
    Richard
    Ziggster and NoSurf like this.
  2. Ziggster
    Ziggster
  3. alchemy
    alchemy
    Yes they were already milled, you can see because the dome above the piston is so small around. Should be the same diameter as the piston.
    First thing they need is cleaned. I blast mine in a sandblast cabinet. It will remove all the corrosion from the surface to show you exactly what remains. Only then can you determine how well they will seal.
    To determine if they are still flat, use a machinists straight edge. Might not need any more milling to straighten them out.
    Then you can determine the clearance above your pistons and valves to see if they might need machining to fit your particular engine.
  4. CSPIDY
    CSPIDY
    If you decide to clean them in in your blasting cabinet use a plastic media for aluminum
    jet996 likes this.
  5. gurrru
    gurrru
    you guys are great,
    thank you
    210superair likes this.
  6. 210superair
    210superair
    from Michigan
    Man you're in Chur.... I used to live in Samedan. Not too far from you....
  7. shorrock
    shorrock
    If you are in doubt you can always come to my place, I am in southern Germany, just 60km from Konstanz.
