Flathead Block and 4"Crank Shaft
Discussion in 'Parts For Sale' started by 45yellowford, Mar 17, 2016.
  1. 45yellowford
    45yellowford
    City: Idaho Falls
    State: Idaho
    Price: in ad
    Are you tired of finding flathead motors only to discover later that they are cracked. This one is not cracked!!! This is the nicest block I have seen in years. I had it hot tanked and maged. The common crack from a headbolt hole to a water passage hole was the only crack. The block has not been rebored and it has only a real small ridge at the top of the cylinder. I am asking $950 or best offer for the block.
    This is the crank from the above block. It has been cleaned, maged and reground. Everything checked out excellent. It is ground M 10, R 20. I am asking $550 or best offer. If you are building a high dollar flathead, this is an excellent place to start.
    The pan, timing gear cover, rods, oil pickup tube, etc are available.
