Flathead Block Useable?
Discussion in 'The Hokey Ass Message Board' started by 19Ford39, Nov 27, 2008.
  1. 19Ford39
    19Ford39
    from Texas
    Well this is block no.3. First two had issues (both 8BA style), this 59A looked pretty good when taking it down. I think it was used for an industrial motor in its last ***ignment (I was told an icehouse). No cracks that I can find. A little rust in the valve area. Standard bore, even crank was standard. I had it tanked to clean out the gunk and noticed the front water pump area on the p***enger side. I thought it was sealer when I first took it apart. Upon furthr instpection it looks to have been broken right between the two holes of the pump. Someone brazed it together again. It is fairly strong as I pried on it some and i don't think it is an area that bears a load (going into 39 truck). I think the other outer bolts bear the load. Has anyone seens this problem before? Should I just grind it smooth and go?
    http://picasaweb.google.com/joptaylo/59Flathead#
    A mild hop up is planned.
    Happy Thanksgiving
    John
  2. AlbuqF-1
    AlbuqF-1
    from NM
    I'm not seeing any bronze?
  3. Dale Fairfax
    Dale Fairfax
    Looks like some amateur had to change a water pump somewhere along the way and didn't know about the hidden bolt inside the pump. He pried on with a big enough bar that he broke the casting. If it's been that way for years, it'll probably last for a few more.
  4. srdart67
    srdart67
    from Sharon, Wi
    personally i wouldnt trust it its just to soft. grind it out and get some tig in there then grind smooth if you must
  5. 19Ford39
    19Ford39
    from Texas
    The camera flash whited out the yellowish color of the brazing. I think that is exactly what happened.
  6. Fraz
    Fraz
    from Dixon, MO
    I'd be more worried about that big pile of metal shavings I see in the 5th picture
  7. Hank37
    Hank37
    Yea grind it out and tig it. There is stress in this area from motor mount.
  8. eaglebeak
    eaglebeak
    There is no pressure on that area. The bolt in the middle is just to seal the gasket. Go ahead with it.
  9. Bill Van Dyke
    Bill Van Dyke
    The problem with block cracks is the end of the crack you can't see. Can you mag light the thing in any way to see what you are really dealing with? The one on the outside looks pretty close to the water jacket. No way would I run it without at least TIGing the visable cracks and refacing. There are some machine shops that used to have blockoff plates to presurize and check for leaks. Don't forget that it may look fine until the block is heated when running.
  10. 29nash
    29nash
    from colorado
    I wouldn't grind on it. I've used permatex hardening type on the gasket on surfaces that looked worse than that with no leaks...
  11. Flat Ernie
    Flat Ernie
    Tech Editor
    Should be fine.
  12. 19Ford39
    19Ford39
    from Texas
    Thanks all. I will have the machine shop look at it as well. Those shavings are from trying to drill out one of two broken head studs.
  13. Shaggy
    Shaggy
    from Sultan, WA
    If it ran before it'll run again
  14. Bruce Lancaster
    Bruce Lancaster
    If crack is between the holes, it is terminated. I would just Loc***e a stud into the hole so threads never have to move again, use a br*** nut.
