Technical flathead blower lower pulley size
Discussion in 'Traditional Hot Rods' started by wheeltramp brian, Oct 24, 2013.
  1. wheeltramp brian
    wheeltramp brian
    have a customers 33 ford 3w coupe running a stock 49 merc flatty.he is going to uprade to a new engine with a scott blower with 3 belt pulley on the crank.the question is how deep is the pulley from the block to the outside of the end groove as this engine is installed with very little room to the crossmember.i may have to move the engine/ trans back if not enough room. thanks
  2. wheeltramp brian
    wheeltramp brian
    somebodys got a blown flathead they can measure
  3. dragsled
    dragsled
    from Panama IA
  4. wheeltramp brian
    wheeltramp brian
  5. woodypecker
    woodypecker
    I have an 8rt with a 4-71 blower and I am using three 5/8 belts. Mine is about 3/4 inch longer than standard two belt. My pulleys are home made.
