Technical flathead blower
Discussion in 'Traditional Hot Rods' started by hotrodnomader, Oct 24, 2013.
  1. hotrodnomader
    hotrodnomader
    I'm thinking of building a flathead with a blower. I've never had a blower motor before. With a blower you obviously get the cool factor of having a blower plus the increase in power, but what are the downfalls/negatives of having a blower ? Other than cost of course.
  2. hotrodderhaag
    hotrodderhaag
    well,
    let me see where i can start... the EGT's are high, the intake temps are high thus causing the motor to run warmer than normal of your not prepaired for it.. timing is a real******, so is getting the plug gap just perfect... its takes alot of time to get two carbs to tune in just right.. if you go with a vintage blower, parts are hard to come by, and i drive mine a lot so its alot of clean oil changes and such to care for it. blowers are a different style of driving. all in all i love my blown flathead. there is nothing more cool to people when they see you drive in with a blown flatty!!
    oh and the sound is great!! mine whistles like a******** when your lead footing it.
  3. Crusty Nut
    Crusty Nut
    Huh, I put a blower on a homebuilt intake, home built drive system and just drove the***** out of it. Sure, you have to fiddle with the carbs a bit, but no more so than 2 carbs on a non-blown set up. Flatheads breathe poorly and IMHO a blower is one of the best things to do to one.
  4. roseville carl
    roseville carl
    Once you get blown you can never go back.........
  5. GOSFAST
    GOSFAST
    No "downfalls", really no "negatives" (not counting the costs of course), they are actually fun to drive.
    Have been involved with more "blown" builds a few years ago, not as many today, but no issues whatsoever.
    The one item I would recommend is a "girdle" that straddles the center main and ties into the pan rails and block web. Pan still works. I made these at one time but have none available anymore. This is not to be confused with the main cap "strap", it has more support. I have a photo of the "pattern", but that's about it.
    Thanks, Gary in N.Y.
    P.S. Here's a shot of one, I believe taken at the N.Y. coliseum, was a 2x4's setup. Have done single 4's as well. And also a shot of the "girdle" pattern.
  6. B Ramsey
    B Ramsey
    there is one that pops up on san diego craigslist every now and then..
  7. Fullraceflathead
    Fullraceflathead
    Hello,
    I made a video back in the 1990's called "Fullrace Flathead"
    I detailed building a 296 Supercharged Flathead that I built for my front Engine dragster.
    Let me know if interested and I can transfer it to a DVD.
    I originally offered it on VHS for $20.00
    That's the Dragster and the same "Fullrace Flathead" that is shown in the Video in my Avitar on the left.
  8. bobadame
    bobadame
    I would be interested in a DVD.
  9. I've got a bunch of flathead stuff that will be for sale soon including a nice blower setup...PM me for details.
    Steve
  10. Kevin Lee
    Kevin Lee
    Super Moderator
    I would as well.
  11. hotrodderhaag
    hotrodderhaag
    ImageUploadedByH.A.M.B.1382665377.365081.jpg ImageUploadedByH.A.M.B.1382665424.592006.jpg
    ImageUploadedByH.A.M.B.1382665612.968533.jpg ImageUploadedByH.A.M.B.1382665750.413824.jpg
  12. Model A Mark
    Model A Mark
    from dallas
    Man thats a good looking set up hotrodderhaag, any idea how much boost that puts in the engine ?
  13. hotrodderhaag
    hotrodderhaag
    I put 3.5-4 lbs at WOT. I'm still having some timing issues with the advance ... Its has the ability to run better once I straighten it out . But it's a good running old flathead
  14. Rusty O'Toole
    Rusty O'Toole
    McCulloch on a stock engine gives about 4 or 5 PSI and 25% more HP.
    Flatheads respond well to supercharging because they have low compression and the breathing is not the best.
    Don't go crazy and you should get 25% - 50% more HP without hurting driveability and reliability too much. 5 - 7 PSI.
    Disadvantages, cost, complexity, weight. One more thing to go wrong. Keep it mild and it shouldn't cause problems.
    PS the above was posted while I was typing but I will let my answer stand.
  15. Model A Mark
    Model A Mark
    from dallas
    Sure is a good looking rig..
  16. hotrodnomader
    hotrodnomader
    thanks for the info
  17. woodypecker
    woodypecker
    PITA to set valve lash.
